[GeoNode-users] Cannot upload shapefiles most of the time
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 13 11:06:51 PDT 2017
Hi, the geonode's 2.6 geoserver is version 2.9.x, and is shipped with it.
If you used another geoserver the auth won't work.  Documents is working
because is not using geoserver
2017-06-13 15:47 GMT+02:00 Jeremiah Zellers <
jeremiah.zellers.wf0d at statefarm.com>:
> This will be a little wordy so I can present what I have tried.
>    1. I am using Geonode 2.6.x and GeoServer 2.1.1.0
>    1. At first I was able to get the shapefiles that came preinstalled
>    with GeoServer to upload
> To GeoNode. They already had their workspaces/stores set up ahead of time.
> I could NOT get shapefiles from my local system to upload. I would get a
> few different Errno 10061, as well as Authentication Errors. This was when
> I tried to upload directly from my C:\ like you can do with the GeoNode
> demo program.
>    1. I then tried creating my own Workspace/Store/Layers through
>    GeoServer and adding those shapefiles to GeoNode that way. I received the
>    same errors.. despite the fact that the preinstalled GeoServer shapefiles
>    uploaded fine.
>    1. I then simply copied my shapefiles into the preinstalled GeoServer
>    Stores where I had successfully installed from previously. This is NOT work.
>    1. I uninstalled everything, reinstalled. And now I cannot even upload
>    the preinstalled shapefiles from GeoServer like I was previously. I get
>    Errno 10061.
> I have been trying to do this for a couple of weeks. I have tried manual
> Windows installations with no success. I have tried Linux installations
> with no success.  I would really appreciate any help you can provide.
> I should add… DOCUMENTS upload just fine…………….. I am profoundly confused
> by this.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170613/cfe8df7a/attachment.html>
More information about the geonode-users mailing list
