[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Tue Jun 20 01:37:36 PDT 2017
Dear Simone,
  Thanks for the responding.  As per I understand from below code in the
proxy/views.py
if not settings.DEBUG:
        if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
            return HttpResponse("DEBUG is set to False but the host of the
path provided to the proxy service"
                                " is not in the PROXY_ALLOWED_HOSTS
setting.",
                                status=403,
                                content_type="text/plain"
 if GeoNode  debug mode value is flase, the wms url may not be required to
add in  PROXY_ALLOWED_HOSTS. And even if debug mode value is ture, it
should show the following error 'DEBUG is set to False but the host of the
setting',. In my case nothing this kind of error/alert message is not
getting
And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site, it is
fetching the layers
However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
= ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is showing
same error.
I have been trying from last two days to overcome this issue, but not able
to do. Please suggest anywhere more I need to investigate the code/settings?
Thanks,
Naresh
On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Naresh, you should add the fase2kort.klimatilpasning.dk
> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
> there.
> I tested locally and seems to work.
> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS =
>> ('192.168.198.209', ) the error, str and tupple can not be concatenated is
>> solved.
>> How ever, not able to add any WMS Layer url, it is showing the following
>> error.
>> For example Layer URL: http://fase2kort.klimatilpasni
>> ng.dk:80/geoserver/wms. Getting the following error.
>> Internal Server Error: /proxy/
>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback (most
>> recent call last):
>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
>> 112, in get_response
>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>> wrapped_callback(request, *callback_args, **callback_kwargs)
>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>> conn.request(request.method, locator, request.body, headers)
>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>> self._send_request(method, url, body, headers)
>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>> self.endheaders(body)
>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>> self._send_output(message_body)
>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>> self.source_address)
>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno 111]
>> Connection refused
>> Even I went to httplib.py and socket.py with the alerts I could able to
>> see the following WMS server IP and port details ('188.64.159.9', 80) and
>> source_address is none
>> Please help me how to resolve the issue, is that any where my GeoNode
>> Deployed System Ip need to place?
>> Thanks,
>> Naresh
>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> It must be an array and not a tuple.
>>> I don't know what ssl misconfiguration could be
>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com> ha
>>> scritto:
>>>> Dear Simone,
>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209')
>>>> and in proxy/views.py linenumber: 37 is reverted means removed ip adress
>>>> and kept as hostname. It is showing following error
>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal Server
>>>> Error: /proxy/
>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback (most
>>>> recent call last):
>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>> cannot concatenate 'str' and 'tuple' objects
>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal Server
>>>> Error: /proxy/
>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback (most
>>>> recent call last):
>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>> cannot concatenate 'str' and 'tuple' objects*
>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622] Misconfiguration
>>>> of certificate's CN and virtual name. The certificate CN has
>>>> localhost4.localdomain4. We expected localhost.localdomain as virtual name.
>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>> length
>>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
>>>> objects ' *will go, how ever the error which I mentioned in my earlier
>>>> mail retains.
>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>> proxy/views.py
>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>> error, since I am not using https any where
>>>> Thanks,
>>>> Naresh
>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>> Not a good idea to modify the python files, You can add the
>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration of
>>>>> it.
>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>  I have tried with the url provided http://demo.genode.org/geoserv
>>>>>> er/wms, getting the following error.
>>>>>> [image: Inline image 1]
>>>>>> *Please find the apaahe error log file and attached views.py file
>>>>>> from proxy folder of geonode for the reference. In view.py in line no: 37
>>>>>> is modified (commented host name and placed IP adrdress of GeoNode
>>>>>> installed system)*
>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>> (most recent call last):
>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>> line 112, in get_response
>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response =
>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>> self.send(msg)
>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>> self.connect()
>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>> self.timeout, self.source_address)
>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno
>>>>>> 111] Connection refused
>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response =
>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>> self.send(msg)
>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>> self.connect()
>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno
>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>> name.
>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>>>>> length
>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>> wrote:
>>>>>>> Dear Simone,
>>>>>>>   Thanks. I will try with the provided url.
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure
>>>>>>>> about our other question, don't think is possible in the standard code.
>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>>>>>> error code.
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue of
>>>>>>>>>> that geoserver.
>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>>>>>>> Geoserver of others and I am adding this
>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms
>>>>>>>>>>> . in demo GeoNode site  and  can be observed same issue.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have
>>>>>>>>>>>>> fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4.
>>>>>>>>>>>>> Not able to understand from where you  observed my Geoserver version is
>>>>>>>>>>>>> 2.0.2?.
>>>>>>>>>>>>>  Please let me know any other information required to solve
>>>>>>>>>>>>> the issue
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>>>>>>>>>> _geoserver_application.html  to configure Geoserver with
>>>>>>>>>>>>>>> GeoNode
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am getting
>>>>>>>>>>>>>>>>>> same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/2aa6051d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/2aa6051d/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/2aa6051d/attachment-0003.png>
More information about the geonode-users mailing list
