[GeoNode-users] Geonode account registrations don't work
Adam Lawrence alaw005 at gmail.com
Sat Mar 11 01:50:30 PST 2017
Hi again  thank you for the help. I ended up using a bit of a hack (I
think), the syncdb error message showed me where to look for the source
files so I changed the settings there. The following are my documented
instructions, in case they are of use to anyone. Is there a reason why the
notifications app is not enabled by default? I wonder because would be so
much easier if it was - is it a performance issue for those that don't need
it?
   #. Configure email server and user registration
      Open config file::
            sudo nano /etc/geonode/local_settings.py
      Locate the following email and user registration settings and update
to your requirements (uncomment relevant settings). NB: If you are using
gmail to send emails then you will need to update gmail settings to allow
less secure connections (otherwise emails will be blocked).
            #REGISTRATION_OPEN = False
            #ACCOUNT_APPROVAL_REQUIRED = False
            #ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
            #ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
            # Uncomment the following to receive emails whenever there are
errors in GeoNode
            # or to be notified of new user requests when
ACCOUNT_APPROVAL_REQUIRED has been set.
            #ADMINS = (
            #            ('John', 'john at example.com'),
            # Uncomment the following to use a Gmail account as the email
backend
            #EMAIL_USE_TLS = True
            #EMAIL_HOST = 'smtp.gmail.com'
            #EMAIL_HOST_USER = 'youremail at gmail.com'
            #EMAIL_HOST_PASSWORD = 'yourpassword'
            #EMAIL_PORT = 587
 Active the ``notification`` app in django.  This is required because the
app is not installed by default (commented out in source code). You will
need to edit the following file (this is a hack, as should only be changing
the local_settings.py file)::
sudo nano /usr/local/lib/python2.7/dist-packages/geonode/settings.py
      Locate the line ``#'notifications',`` and uncomment so becomes
``'notifications',``
INSTALLED_APPS = (
#'notification',
) + GEONODE_APPS
      Then apply the settings as follows:
            sudo geonode syncdb
            sudo service apache2 restart
On 11 March 2017 at 20:42, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> I see I might be a circular import issue. I haven't actually tried it :)
> usually this type of customization is done through a Geonode project.
> So then copy again all installed apps. And also the geonode apps and
> uncomment notification.
> Il giorno ven 10 mar 2017 alle 23:23 Adam Lawrence <alaw005 at gmail.com> ha
> scritto:
>> Hi,
>> Thank you and I like that solution better! Only problem is I still get an
>> 500 error, and when I tried syncdb I get the following error:
>> $ sudo geonode syncdb
>> Traceback (most recent call last):
>>   File "/usr/bin/django-admin.py", line 5, in <module>
>>     management.execute_from_command_line()
>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> line 399, in execute_from_command_line
>>     utility.execute()
>> line 392, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>> line 261, in fetch_command
>>     commands = get_commands()
>> line 107, in get_commands
>>     apps = settings.INSTALLED_APPS
>>   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
>> 54, in __getattr__
>>     self._setup(name)
>> 49, in _setup
>>     self._wrapped = Settings(settings_module)
>> 128, in __init__
>>     mod = importlib.import_module(self.SETTINGS_MODULE)
>>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>> line 40, in import_module
>>     __import__(name)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/settings.py",
>> line 871, in <module>
>>     from local_settings import *  # noqa
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/local_settings.py",
>> line 110, in <module>
>>     INSTALLED_APPS = geonode.settings.INSTALLED_APPS + ('notification',)
>> AttributeError: 'module' object has no attribute 'settings'
>> On 11 March 2017 at 00:45, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>> oh right I forgot the geonode apps. Ok discard the previous and try with
>> this one
>> 2017-03-10 12:37 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>> On 11 March 2017 at 00:16, Adam Lawrence <alaw005 at gmail.com> wrote:
>> Thank you, but unfortunately it still doesn't work. I have pasted the
>> following into my local_sttings.py from https://github.com/
>> GeoNode/geonode/blob/master/geonode/settings.py but I now get a server
>> error 500 code on all pages. I did a sudo service apache2 restart after the
>> change but do I also need to restart something else?
>> INSTALLED_APPS = (
>> 'modeltranslation',
>> # Boostrap admin theme
>> # 'django_admin_bootstrapped.bootstrap3',
>> # 'django_admin_bootstrapped',
>> # Apps bundled with Django
>> 'django.contrib.auth',
>> 'django.contrib.contenttypes',
>> 'django.contrib.sessions',
>> 'django.contrib.sites',
>> 'django.contrib.admin',
>> 'django.contrib.sitemaps',
>> 'django.contrib.staticfiles',
>> 'django.contrib.messages',
>> 'django.contrib.humanize',
>> 'django.contrib.gis',
>> # Third party apps
>> # Utility
>> 'pagination',
>> 'taggit',
>> 'treebeard',
>> 'friendlytagloader',
>> 'geoexplorer',
>> 'leaflet',
>> 'django_extensions',
>> #'geonode-client',
>> # 'haystack',
>> 'autocomplete_light',
>> 'mptt',
>> # 'modeltranslation',
>> 'djcelery',
>> 'storages',
>> 'floppyforms',
>> # Theme
>> "pinax_theme_bootstrap_account",
>> "pinax_theme_bootstrap",
>> 'django_forms_bootstrap',
>> # Social
>> 'account',
>> 'avatar',
>> 'dialogos',
>> 'agon_ratings',
>> # 'notification',
>> 'announcements',
>> 'actstream',
>> 'user_messages',
>> 'tastypie',
>> 'polymorphic',
>> 'guardian',
>> 'oauth2_provider',
>> ) + GEONODE_APPS
>> On 11 March 2017 at 00:01, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>> The easiest way is to copy the installed apps block from the default
>> settings, see in github, and copy in your /etc/geonode/local_settings.py
>> uncommenting notifications.
>> Il giorno ven 10 mar 2017 alle 11:36 Adam Lawrence <alaw005 at gmail.com>
>> ha scritto:
>> Hi, thank  you for the advice. Can you please advise how to access the
>> installed apps settings if I've used the PPA install method or is that not
>> possible?
>> On 10 March 2017 at 21:55, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>> Hi, you have to also uncomment "notifications" in the settings installed
>> apps. then run syncdb. If that is missing from the doc then we need to fix
>> it.
>> 2017-03-10 5:09 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>> Hi,
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170311/7107694e/attachment-0001.html>
More information about the geonode-users mailing list
