[GeoNode-users] Authentication problem between Geonode and Geoserver
Joshi, Jigeeshu Jigeeshu.Joshi at ils-forschung.de
Fri Jul 6 05:15:18 PDT 2018
Hi Alessio,
Do you mean Geofence Data Rules ?  There are three option undere Security :
1.       Geofence
2.       Geofence Data Rules
3.       Geofence Admin rules
Geofence data rules looks like one in the image attached.
Thanks
Joshi
Von: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
Gesendet: Freitag, 6. Juli 2018 14:09
An: Joshi, Jigeeshu
Cc: geonode-users
Betreff: Re: [GeoNode-users] Authentication problem between Geonode and Geoserver
It looks like GeoFence rules for Layers have not been created on GeoServer.
1. Check that changing Layer permissions GeoFence Rules are created on GeoServer GeoServer Admin GUI > Security > GeoFence Rules
2. Check that the options
        'GEONODE_SECURITY_ENABLED': True,
        'GEOFENCE_SECURITY_ENABLED': True
have been correctly set on settings > OGC_SERVER
Il giorno ven 6 lug 2018 alle ore 13:40 Joshi, Jigeeshu <Jigeeshu.Joshi at ils-forschung.de<mailto:Jigeeshu.Joshi at ils-forschung.de>> ha scritto:
Hi ,
I am having trouble understanding the authentication / authorization settings between Geonode and Geoserver. I have a problem that , the layers in Geonode are not available/ visible unless logged into Geosever with user admin. After login to Geoserever as admin, everything works normally.  But, every user does not have Geoserver admin credential so in that case, any user other than admin would not be able to see the layers.
Has anyone come across this problem. Any solution is appreciated. Let me know if I have not made the problem clear.
Regards,
Joshi
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180706/e866d6a5/attachment-0001.html>
Type: image/png
Desc: geofence_data_rules.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180706/e866d6a5/attachment-0001.png>
More information about the geonode-users mailing list
