[OpenLayers-Users] How to make OpenLayers.Popup draggable?
Yasemin YILMAZ yasemin.yilmaz.embedded at gmail.com
Tue Aug 28 04:01:41 PDT 2012
Hi all,
I've used jquery-ui draggable option as following but the moving popup can
not be ended once dragging has started. Is there any another method to make
                    popup = new OpenLayers.Popup.AnchoredBubble(
"JInfo",        //
id
jFeature.geometry.getBounds().getCenterLonLat(),  // lonlat
                                                            new
OpenLayers.Size(ISA.Size.POPUP_WIDTH, ISA.Size.POPUP_HEIGHT),
html,                                             // contentHTML
null,                                              // anchor
true,                                             // closeBox
                                                            function()
{                                    // closeBoxCallback
jSelectControl.unselect(jFeature);
                    jFeature.popup = popup;
                    map.addPopup(popup);
                    $("#JInfo").draggable();
Thanks advance for your helps,
Yasemin
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120828/3c0e0ee5/attachment.html>
