[QGIS-Developer] Building QGIS with Visual Studio 2019 CE and vcpkg
Benjamin Jakimow benjamin.jakimow at geo.hu-berlin.de
Mon Mar 1 21:58:46 PST 2021
Hello Stefan.
in my local repo I updated libspatialindex\portfile.cmake to 1.9.3 by
vcpkg_from_github(
     OUT_SOURCE_PATH SOURCE_PATH
     REPO libspatialindex/libspatialindex
     REF 1.9.3
     SHA512
d4c608abbd631dc163b7b4fb6bf09dee3e85ce692a5f8875d51f05a26e09c75cd17dff1ed9d2c232a071f0f5864d21d877b4cbc252f3416896db24dfa3fa18cb
     HEAD_REF master
and removed the older patchfile.
However, in the end I had to give up, because MSVC did not compile Exiv2
with C++17.
Best regards,
Benjamin
On 2021-03-01 16:35, Uhrig, Stefan wrote:
> Hi Benjamin,
> Thanks for the feedback.
> AFAIK, QGIS has only recently be bumped to C++17, and the version of
> spatialindex in vcpkg is still 1.9.0. The fix for the binary_function
> issue made it to a later version only. So, the bad news is that the
> build with vcpkg is broken for now.
> I've read Mathias Kuhn's mail, and his idea of having a curated vcpkg
> fork seems the best approach to me to solve these kind of issues. On
> the one hand, we can prevent changes in upstream from breaking the
> build. On the other hand, we can update dependencies on our own (like
> the spatialindex library), merge it to the fork and then open a pull
> request to upstream. We would not be blocked by the upstream review
> process that way.
> I'll fork vcpkg and I'll try to update the spatialindex library. If I
> succeed, I'll mail you the link to the repository.
> Best regards,
> Stefan
> From: Benjamin Jakimow <benjamin.jakimow at geo.hu-berlin.de>
> Sent: Sunday, February 28, 2021 9:03 AM
> To: Mats Taraldsvik <mats.taraldsvik at gmail.com>
> Cc: Uhrig, Stefan <stefan.uhrig at sap.com>; qgis-developer
> <qgis-developer at lists.osgeo.org>
> Subject: Re: [QGIS-Developer] Building QGIS with Visual Studio 2019 CE
> and vcpkg
> Hi Stefan,
> thanks for your extensive description. So far it worked out very well
> to setup VS, and I can confirm that geos_c.lib is detected
> automatically.
> Unfortunately my build failed, because MovingRegion.h (which comes with
> vcpkg) wants to use std::binary_function, which was removed with C++17:
> <vcpkg
> root>\installed\x64-windows\include\spatialindex\MovingRegion.h(155):
> error C2039: 'binary_function': is not a member of 'std'
> I wonder why, because this issue has been solved in libspatialindex
> since Oct 2019
> (https://github.com/libspatialindex/libspatialindex/pull/153)
> Best regards,
> Benjamin
> On 2021-02-11 11:29, Mats Taraldsvik wrote:
> Hi Stefan,
> Thank you for this excellent guide to compile with vcpkg, it worked
> right away after me struggling with the official guide+CMake
> compilation for a couple of hours.
> I did make a few modifications that might help:
> 1. Release build:
> - geos_c.lib was detected automatically, and for some reason I did not
> need to explicitly set GEOS_LIBRARY
> 2. Debug build:
> I noticed: 1> [CMake] -- Found ZSTD:
> C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/lib/zstd.lib
> in the logs and you wrote:
>> The build will fail because the execution of crssync.exe fails. That's
>> because crssync.exe tries to load zstd.dll instead of zstdd.dll. I
>> haven't figured out why, yet. An easy workaround is copying zstdd.dll
>> to zstd.dll in QGIS\out\build\x64-Debug\output\bin. Then restart the
>> build and it should succeed.
> By setting ZSTD_LIBRARY explicitly to
> <your-vcpkg-root>/installed/x64-windows/debug/lib/zstdd.lib it picked
> the right lib and dll:
> Then log changed to: 1> [CMake] -- Found ZSTD:
> C:/Users/mattar/Source/Repos/vcpkg_qgis/installed/x64-windows/debug/lib/zstdd.lib
> I hope this does help a bit.
> I'm an outsider to this community, but my humble suggestion _when this
> work is complete_ (what's missing except for python support?):
> - add your CMakeSettings.json to the build description or to
> src/CMakeSettings.json
> - vcpkg has a new feature "manifests", where a file vcpkg.json
> describes all dependencies. this should also be added or described
> (instead of the vcpkg install command).
> - vcpkg just got versioning, which might help align the requirements
> with the rest of qgis
> - I see that vcpkg already has flex and bison
> (<your-vcpkg-root>/downloads/tools/winflexbison), so if there is a way
> for win_bison.exe and win_flex.exe to be copied to the build directory,
> these could be used instead of cygwin, making the build even easier)
> - vcpkg does have binary caching, perhaps making a github actions CI
> build using this method feasible?
> Anyway, thank you for your efforts! It made the first QGIS-step more
> pleasant. :)
> Best regards,
> Mats Taraldsvik
> On Mon, Feb 1, 2021 at 4:24 PM Uhrig, Stefan <stefan.uhrig at sap.com>
> wrote:
> Hi all,
> In my opinion, the build with Visual Studio 2019 and vcpkg is still too
> experimental to add it to the INSTALL.md file. It might break any day
> if QGIS requires a package or package version that is not available
> from vcpkg.
> Actually, I like the idea to add it to the "Show & tell" category. We
> can ask the community for their experiences with that setup. Does it
> work, is it getting used? If it is used by some "critical mass" and
> works over a longer time without issues, we can add instructions to the
> INSTALL.md file. Maybe we can add a hint to the INSTALL.md file that
> the not so faint-hearted developers might give it a try and provide a
> link to the "Show & tell" post.
> However, to be really useful, the debug build should also work with
> Python bindings and QGIS processing. I got it working for release
> builds (just needed to install the required Python dependencies via pip
> install <package>), but that does not work for debug builds. Someone
> solved that some years ago in another context
> (https://www.riverbankcomputing.com/pipermail/pyqt/2012-April/031385.html),
> so I might get it working. I'll give it a try.
> Furthermore, I'd like to investigate the zstd.dll vs zstdd.dll load
> issue before publishing the build instructions.
> Best regards,
> Stefan
> From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On Behalf
> Of DelazJ
> Sent: Monday, February 1, 2021 10:49 AM
> To: Jorge Gustavo Rocha <jgr at di.uminho.pt>
> Cc: qgis-developer <qgis-developer at lists.osgeo.org>
> and vcpkg
> Hi,
> Why not in the build instructions of the code repo instead:
> https://github.com/qgis/QGIS/blob/master/INSTALL.md? If it's a working
> process, easy to replicate, this is the place I'd expect this kind of
> information.
> Regards,
> Harrissou
> Le dim. 31 janv. 2021 à 15:55, Jorge Gustavo Rocha <jgr at di.uminho.pt> a
> écrit :
> Hi Stefan,
> We have now a new tab on github called 'discussions'[1]. Your detailed
> instructions are a good candidate to write down a new entry there,
> under
> 'Show and tell' category. The goal is to keep this information next to
> the repo. You can use the markdown syntax to enhance the writing
> format.
> You can also add some print screens.
> This is just a suggestion. Feel free to put it there or not.
> Regards (and thank you!),
> Jorge Gustavo
> [1] https://github.com/qgis/QGIS/discussions
> Às 14:13 de 31/01/21, Uhrig, Stefan escreveu:
>> Install Visual Studio Community 2019: Select "Desktop development with
>> C++" under "Workloads" and "C++ MFC for latest v142 build tools (x86 &
>> x64)" under "Individual components". Verify that you install "Windows
>> 10
>> SDK (10.0.18362.0)" or higher.
>> Install Git for Windows and Python 3.
>> Download
>> https://sourceforge.net/projects/winflexbison/files/win_flex_bison3-latest.zip/download
>> [1]
>> and extract it to a location of your choice (avoid space characters in
>> the target path).
>> Follow the vcpkg "Quick Start: Windows" instructions at
>> https://github.com/microsoft/vcpkg#quick-start-windows [2]. Make sure
>> to
>> execute the "vcpkg integrate install" command.
>> Install the required dependencies via:
>> vcpkg --triplet=x64-windows install exiv2 gdal gsl libspatialindex
>> libspatialite libzip opencl protobuf qca qscintilla qt5 qt5-serialport
>> qt5-location qt5-winextras qtkeychain qwt zstd
>> This may take a while as this creates a Debug and a Release build of
>> each dependency from source.
>> Clone the QGIS repostiory. The path to the QGIS repository should not
>> contain any space characters.
>> Start Visual Studio and open the QGIS CMakeLists.txt file via "File
>> Open --> CMake...". This will start the CMake generation, which will
>> fail. You will need several configuration rounds until everything is
>> setup properly.
>> Let's start with a Release build because that requires less tweaking.
>> Go
>> to "Project --> CMake Settings". Delete the default configuration
>> ("x64-Debug (default)").
>> Add a new "x64-Release" configuration and set "Configuration type" to
>> "Release". Save the CMakeSettings.json file, which will start a new
>> CMake generation. "FIND_FLEX" will fail, so you need to set the
>> "FLEX_EXECUTABLE" path manually in section "CMake variables and
>> cache".
>> Browse to your win_flex.exe file. Additionally, disable
>> "WITH_BINDINGS"
>> and "WITH_QGIS_PROCESS". Save the file. Next set "BISON_EXECUTABLE" to
>> your win_bison.exe file and save again. Disable "WITH_QTWEBKIT" and
>> save. Set "QCA_LIBRARY" to
>> "<vcpkg-root>\installed\x64-windows\lib\qca.lib" and save.
>> Configuration
>> should now succeed, but you have to change "GEOS_LIBRARY" from
>> "geos.lib" to "geos_c.lib". Save and start the build after CMake
>> generation has finished.
>> Select "qgis.exe (output\bin\qgis.exe)" as start-up item in the
>> toolbar
>> and start QGIS.
>> Now let's do the same for a Debug build. Add a "x64-Debug"
>> configuration
>> and save. Change to the "x64-Debug" configuration in the toolbar.
>> Repeat
>> the steps from above (set flex and bison paths etc.). When selecting
>> libraries, take the libraries from
>> "<vcpkg-root>\installed\x64-windows\debug\lib". Most libraries will
>> have
>> a "d" or "_d" as name suffix. The CMake generation will not always
>> select the debug versions of libraries. Hence, go over the CMake
>> variables and change release library paths to debug library paths,
>> e.g.
>> "<vcpkg-root>\installed\x64-windows\debug\lib\geos_cd.lib" for
>> GEOS_LIBRARY. I'll append my CMakeSettings.json file as reference to
>> this mail. Save again and start the build.
>> to
>> build
>> You should then be able to start and debug qgis.exe and its
>> dependencies. Note that some vcpkg portfiles forget to copy over the
>> .pdb files. For example, proj is affected. If you find such a library
>> with a missing .pdb file, check whether the portfile (e.g.
>> "<vcpkg-root>\ports\proj4\portfile.cmake") contains the
>> "vcpkg_copy_pdbs()" call. If not, just add it at the end, re-install
>> the
>> dependency and copy over the .pdb file to the QGIS output directory.
>> I'm currently trying to get QGIS working with Python bindings. I got
>> the
>> build working, however I'm struggling with the debug build execution.
>> The debug Python library seems to be unable to load the Release build
>> Qt
>> libraries that come with PyQt5. Well, I'll keep trying and if I
>> succeed,
>> I'll update the instructions.
>> Here is my CMakeSettings.json file for reference:
>> "configurations": [
>> "name": "x64-Release",
>> "generator": "Ninja",
>> "configurationType": "Release",
>> "buildRoot": "${projectDir}\\out\\build\\${name}",
>> "installRoot": "${projectDir}\\out\\install\\${name}",
>> "cmakeCommandArgs": "",
>> "buildCommandArgs": "",
>> "ctestCommandArgs": "",
>> "inheritEnvironments": [ "msvc_x64_x64" ],
>> "variables": [
>> "name": "WITH_BINDINGS",
>> "value": "False",
>> "type": "BOOL"
>> "name": "WITH_QGIS_PROCESS",
>> "value": "False",
>> "type": "BOOL"
>> "name": "FLEX_EXECUTABLE",
>> "value": "C:/src/tools/win_flex.exe",
>> "type": "FILEPATH"
>> "name": "BISON_EXECUTABLE",
>> "value": "C:/src/tools/win_bison.exe",
>> "type": "FILEPATH"
>> "name": "WITH_QTWEBKIT",
>> "value": "False",
>> "type": "BOOL"
>> "name": "QCA_LIBRARY",
>> "value": "C:/src/vcpkg/installed/x64-windows/lib/qca.lib",
>> "type": "FILEPATH"
>> "name": "GEOS_LIBRARY",
>> "value": "C:/src/vcpkg/installed/x64-windows/lib/geos_c.lib",
>> "type": "FILEPATH"
>> "name": "x64-Debug",
>> "configurationType": "Debug",
>> "variables": [
>> "type": "FILEPATH"
>> "type": "FILEPATH"
>> "value": "False",
>> "type": "BOOL"
>> "value": "False",
>> "type": "BOOL"
>> "value": "False",
>> "type": "BOOL"
>> "value": "C:/src/vcpkg/installed/x64-windows/debug/lib/qcad.lib",
>> "type": "FILEPATH"
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/geos_cd.lib",
>> "type": "FILEPATH"
>> "name": "GSL_LIB",
>> "value": "C:/src/vcpkg/installed/x64-windows/debug/lib/gsld.lib",
>> "type": "FILEPATH"
>> "name": "GSLCBLAS_LIB",
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/gslcblasd.lib",
>> "type": "FILEPATH"
>> "name": "PROJ_LIBRARY",
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/proj_d.lib",
>> "type": "FILEPATH"
>> "name": "QSCINTILLA_LIBRARY",
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/qscintilla2_qt5d.lib",
>> "type": "FILEPATH"
>> "name": "QTKEYCHAIN_LIBRARY",
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/qt5keychaind.lib",
>> "type": "FILEPATH"
>> "name": "QWT_LIBRARY",
>> "value": "C:/src/vcpkg/installed/x64-windows/debug/lib/qwtd.lib",
>> "type": "FILEPATH"
>> "name": "SPATIALINDEX_LIBRARY",
>> "value":
>> "C:/src/vcpkg/installed/x64-windows/debug/lib/spatialindex-64d.lib",
>> "type": "FILEPATH"
>> *From:*i-s-o <46.i.s.o.64 at gmail.com>
>> *Sent:* Saturday, January 30, 2021 5:58 PM
>> *To:* Uhrig, Stefan <stefan.uhrig at sap.com>
>> *Cc:* qgis-developer <QGIS-Developer at lists.osgeo.org>
>> *Subject:* Re: [QGIS-Developer] Building QGIS with Visual Studio 2019
>> CE
>> and vcpkg
>> I am very interested in trying out your solution. Could you share the
>> required steps?
>> Thx.
>> On Fri, Jan 29, 2021, 09:25 Uhrig, Stefan <stefan.uhrig at sap.com
>> <mailto:stefan.uhrig at sap.com>> wrote:
>> TL;DR: It is currently possible to build the QGIS core app with
>> Visual Studio 2019 and vcpkg, which makes debugging QGIS
>> dependencies easy.
>> Hi all,
>> Some time ago I discovered vcpkg
>> (https://github.com/microsoft/vcpkg). vcpkg is a package manager
>> that downloads package source code to your local machine and builds
>> the package locally. Recently, I discovered that vcpkg should be
>> able to provide all dependencies to build at least the QGIS core
>> application. Hence, I gave it a try.
>> Basically, it worked out of the box. I started with a fresh Windows
>> 10 installation, installed Visual Studio 2019 Community Edition,
>> Git, vcpkg, Python 3 and flex and bison for Windows. I fetched all
>> other dependencies via vcpkg. It was not necessary to even touch a
>> single file in the repository. I could just open the main
>> CMakeLists.txt file in Visual Studio and only had to tweak the CMake
>> cache (the CMake find macros that come with QGIS are not aware of
>> vcpkg, so I had to set some paths manually). I had to switch off
>> some extensions though as the required dependencies were not
>> available via vcpkg (WITH_BINDINGS, WITH_QGIS_PROCESS,
>> WITH_QTWEBKIT). The build did not report any errors, I could start
>> the application and it seems to work, but I did some light testing
>> only.
>> I mainly tried it because I enjoy debugging with Visual Studio more
>> than with gdb (or gdb wrapped in some IDE). In my experience, the
>> performance of the Visual Studio debugger is better and it is more
>> stable, especially in long debug sessions.
>> I don't want to promote official building support of QGIS with
>> vcpkg. Providing the dependencies via OSGeo4W is much more reliable.
>> However, if you don't mind the experimental nature of this setup and
>> you want to be able to debug into QGIS' dependencies, you might give
>> it a try. Especially, if you want to track the cause of a crash in
>> one of QGIS' dependencies, this setup might be helpful. You have the
>> source code and debug versions of the dependencies, so the debugger
>> will jump to the crashing code line and you can inspect all the
>> variables of the dependency.
>> If someone is interested in trying it, give me a note. I can then
>> assemble detailed instructions on how to make it work. It took me a
>> while to figure out which packages are needed and how the CMake
>> cache needs to be tweaked.
>> Best regards,
>> Stefan
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [3]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [3]
>> [3]
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
> [3]
> [3]
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [3]
Benjamin Jakimow, Doctoral Researcher
Earth Observation Lab | Geography Department | Humboldt-Universität zu
Berlin
e-mail: benjamin.jakimow at geo.hu-berlin.de
phone:  +49 (0) 30 2093 6894
mobile: +49 (0) 157 5656 8477
fax:    +49 (0) 30 2093 6848
mail:   Unter den Linden 6 | 10099 Berlin | Germany
room: 2'222
Berlin
room: 2'222
Links:
[1]
[2] https://github.com/microsoft/vcpkg#quick-start-windows
[3] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210302/b4be2819/attachment-0001.html>
More information about the QGIS-Developer mailing list
