[QGIS-Developer] qgis ubuntu 20.04 dependencies
Hugh Kelley hghklly at gmail.com
Mon Jun 19 11:33:56 PDT 2023
Of course as soon as I hit send I finally noticed that qt >= 5.14 is listed
in the dependencies so that resolves my key question about a workaround.
Disregard unless anyone knows the best way to handle Qt version for 20.04.
I'm planning to ask on the qt forum.
On Mon, Jun 19, 2023 at 2:30 PM Hugh Kelley <hghklly at gmail.com> wrote:
> Hi all,
> while working on compiling qgis on ubuntu using these instructions [0] ,
> i've run into an error while running cmake that "QRecursiveMutex" is not
> found.
> It looks like that became available in QT 5.14.
> Ubuntu 20.04 installs QT 5.12. During my searches i've seen comments that
> imply 5.15 might not be available for 20.04.  I'm trying to figure out
> whether I should be trying to upgrade Qt, if I have to upgrade Ubuntu, or
> if there is some option in the compilation process that can resolve this
> for me.
> I've installed Qt 5.15.2 to /opt/ and added it to PATH, but qtdiag still
> indicates i'm using 5.12.x
> I thought i'd start by asking here before asking on a Qt general forum in
> case there's a qgis specific solution.
> I've also set the cmake 3d option to "no" which got me around the absence
> of q qt 3d extras pacakge/file.  So maybe there's a similar solution for
> this although this version problem seem more essential.
> Thanks for any suggestions!
> [0] https://github.com/qgis/QGIS/blob/master/INSTALL.md
> Hugh Kelley
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230619/f52df04c/attachment.htm>
More information about the QGIS-Developer mailing list
