[QGIS-Developer] Paste geometry functionality
Régis Haubourg regis.haubourg at gmail.com
Wed Nov 29 05:53:09 PST 2023
Hi Tomas,
copy-paste geometric features is implemented for years now, and copying
to a spreadsheet or text file also.
There is a setting if you don't want the geometry to be pasted as a WKT
column in text/ spreadsheet format.
The behavior of attribute forms can also be tuned by options regarding
the attribute of newly created features
Can you be more precise on your use case scenario ?
Regards
Régis
On 28/11/2023 21:37, Tomas Straupis via QGIS-Developer wrote:
> Hello
>    I was wondering, is there any reason why "paste geometry" (for
> vector features) is not implemented in QGIS? Or is it simply because
> nobody implemented it (I'm thinking of trying to do that)?
>    The use case is different government cadastres where geometry is
> provided by external institutions and institution responsible for
> maintaining the cadastre is adding the attribute values. While they
> can use full feature paste (with attributes) for initial record
> creation, updating requires the possibility to paste geometry only
> without changing any attribute values.
>    Thank you
> P.S. I am aware of a python plugin for that but it does not work for
> large geometries as clipboard size limit is reached pretty fast on
> windows.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231129/8f4c3777/attachment.htm>
More information about the QGIS-Developer mailing list
