[Conference-resources] Request to create CfP of academic track and workshop for FOSS4G 2026 Hiroshima
Jin Igarashi
igarashi.jin at water-gis.com
Wed Sep 17 15:40:57 PDT 2025
Hi Vicky san,
Thank you for creating events for FOSS4G Hiroshima. I can see them in
pretalx now.
general track's short form is "*foss4g-hiroshima-2026-general-track*"
currently. Should it be like "*foss4g-2026*" like other global ones did? So
URL will be consistent.
Also, academic track's short form can be "*foss4g-2026-academic-track*"
instead of "*foss4g-2026-academic*"?
[image: image.png]
I cannot change the short form URL. Could you change them to be consistent
with previous global FOSS4G events?
Previous URLs look like below for your references (I found it from this API
https://talks.osgeo.org/api/events/)
2025 does likely have academic and workshop separately
https://talks.osgeo.org/foss4g-2025/
2024
https://talks.osgeo.org/foss4g-2024/
https://talks.osgeo.org/foss4g-2024-academic-track/
https://talks.osgeo.org/foss4g-2024-workshop/
2023
https://talks.osgeo.org/foss4g-2023/
https://talks.osgeo.org/foss4g-2023-academic-track/
https://talks.osgeo.org/foss4g-2023-workshop/
Kind regards,
Jin
2025年9月18日(木) 2:23 Vicky Vergara <vicky at erosion.dev>:
> Hi all
> Create the events under FOSS4G organizer
> Created the team: FOSS4G 2626 admin
> Sent the invitations to join the team to all members on the admin team of
> OSGeo.JP
> Note the events can not be deleted therefore I renamed the ones on
> OSGeo.JP with the prefix DO NOT USE with a 2023 year so it does not
> gets deployed.
> Regards
> VIcky
> On Wed, Sep 17, 2025 at 10:56 AM Vicky Vergara <vicky at erosion.dev> wrote:
>> Will create the new ones, will let you delete the ones under OSGEO.Jp
>> control
>> On Wed, Sep 17, 2025 at 7:41 AM Jin Igarashi <igarashi.jin at water-gis.com>
>> wrote:
>>> Hi Vicky san,
>>> I am sorry, I did not notice your email and sent another email to you
>>> about 2 hours ago. It was weird I did not receive any notification for your
>>> responded email to me...
>>> Actually, I created academic one and workshop one under OSGEO JP...
>>> [image: image.png]
>>> I just started writing my first draft of CfP for workshop.
>>> https://talks.osgeo.org/orga/event/foss4g-jp-2026-workshops/
>>> If FOSS4G 2026 CfP needs to be created under FOSS4G International
>>> organizer, please do create three of them under FOSS4G organizer team.
>>> You can delete existing general one and academic one, but don't delete
>>> workshop one from OSGeo JP (I will transfer texts to new one for workshop).
>>> Thanks
>>> Jin Igarashi
>>> 2025年9月17日(水) 10:10 Vicky Vergara <vicky at erosion.dev>:
>>>> To keep consistency I will do the change for the general trac
>>>> Add the teams with members from OSGEO.JP organization
>>>> I'll do that tomorrow first thing, I just need a reply from Igarashi
>>>> San about that he is aware of the change, Before I actually do the change.
>>>> Regards
>>>> Vicky
>>>> On Tue, Sep 16, 2025 at 3:00 PM Luca Delucchi <lucadeluge at gmail.com>
>>>> wrote:
>>>>> On Tue, 16 Sept 2025 at 19:10, Vicky Vergara <vicky at erosion.dev>
>>>>> wrote:
>>>>>> Hello Igarashi San
>>>>> Hi Vicky, Igarashi San
>>>>>> I added you as a team member of FOSS4G Japan admin.
>>>>>> I think something is wrong.
>>>>>> Luca: please correct me if I am wrong:
>>>>>> The FOSS4G international organizer is supposed to be FOSS4G
>>>>>> not OSGeo.JP
>>>>>> I created the workshop and academic trac instinctively using the
>>>>>> FOSS4G organizer.
>>>>>> So right now there are:
>>>>>> The general trac with OSGeo.JP as organizer <- I think this should
>>>>>> be FOSS4G as organizer
>>>>>> The academic trac with FOSS4G as organizer
>>>>>> The workshop trac with FOSS4G as organizer
>>>>>> The registered reviewers for the international event are registered
>>>>>> That is the main reason I think it is not OSGEO.JP the organizer.
>>>>> Yeah, we created different teams under the FOSS4G organizer, probably
>>>>> we should continue like that but for me it could be also good to use the
>>>>> OSGeo.JP organizer, I don't see big differences. I probably made a mistake
>>>>> when I created the general track but I'm not able to change the organizer.
>>>>>> This is the history of the event of the general trac:
>>>>>> [image: image.png]
>>>>>> I can see that it has not been worked out yet.
>>>>>> And of course the recently created ones have not been modified yet
>>>>>> either.
>>>>>> It's a good time to fix whatever needs to be fixed.
>>>>>> I Just need Luca's confirmation about which to fix.
>>>>>> About the fix:
>>>>>> I could not find that pretalx can change organizer, so I think the
>>>>>> way to standardize the organizer is:
>>>>>> Create the event(s) with the correct organizer and remove the
>>>>>> one(s) with the wrong organizer
>>>>>> If the organizer is FOSS4G then create a new team under that
>>>>>> organizer that has all the OSGEO.JP team members
>>>>>> I need Luca to confirm.
>>>>>> Yeah in the previous years were like that.
>>>>>> Regards
>>>>>> Vicky
>>>>> ciao
>>>>> Luca
>>>>> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250917/ad0d2794/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250917/ad0d2794/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250917/ad0d2794/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250917/ad0d2794/attachment-0002.png>
More information about the Conference-resources
