[FOSS-GPS] RTKLib processing power
Michele Bavaro
mic.bavaro at yahoo.co.uk
Wed Oct 2 15:22:59 PDT 2013
I second Josh, I had RTKLIB running on Olinuxino iMX233.. rubbish
floating point but still could do 2Hz off a uBlox NEO6P :)
Michele
On 03/10/2013 00:04, Josh Leighton wrote:
> Hi Weber,
> There's nothing specific to the A9 that would make compiling RTKLib a
> problem. Whether you encounter trouble will most likely depend on
> what linux distribution you end up running.
> We compile the linux kernel ourselves so we can build our own debian
> image, where apt-get makes life pretty easy when it comes to compiling
> RTKLib or other such libraries. Depending on the community support
> for your hardware and what pre-built images are available, debian may
> or may not be an option for you. I always recommend others to use
> debian because it makes package management and compatibility so easy.
> I don't think RTKLib has many dependencies though, so regardless of
> what you're running you should have an easy time of it.
> Best of luck,
> -Josh
> On Tue, Oct 1, 2013 at 3:32 PM, weber de souza calixto
> <webersouzacalixto at gmail.com <mailto:webersouzacalixto at gmail.com>> wrote:
> Josh,
> I'm back on this project.
> A question: Did you have problems to compile RTKLib to A9 processor?
> In the following weeks I will to compile it, I'm just waiting my
> dev board to arrive
> (http://br.embeddeddeveloper.com/tools/2654/Newark-element14/MCIMX6Q-SL.htm)
> Weber
> 2013/8/22 weber de souza calixto <webersouzacalixto at gmail.com
> Hi,
> Josh thanks for sharing your experience. Sure it is helping me
> a lot to choose the processing platform. Right now I`m
> inclined to choose a quad-core 1.2 Ghz A9 to start testing.
> Danny, to use raspberry or beaglebone is dependant on your
> needs. In my case I cant wait RTKLib to compute and then shoot
> the picture. Airplanes can`t hover :)
> Weber
> 2013/8/22 Danny Miller <dannym at austin.rr.com
> <mailto:dannym at austin.rr.com>>
> What about Raspberry Pi and Beaglebone Black?
> Danny
> On 8/21/2013 7:42 PM, Josh Leighton wrote:
>> While I can't speak very scientifically, I can report on
>> our experiences running rtklib on gumstix embedded linux
>> computers. Previous we used a Gumstix Overo with an ARM
>> cortex-A8 (single core) at 800MHz I believe. We couldn't
>> reliably do more than 1Hz RTK alongside the other
>> processes we were running. If I recall correctly,
>> rtknavi was using ~15% cpu at 1Hz.
>> Now with a Duovero (dual core, arm cortex-A9 at 1GHz) we
>> have no problem running RTK at 5Hz. Cpu usage is still
>> around 15%.
>> Hope that's of some help to you.
>> -Josh
>> On Wed, Aug 21, 2013 at 8:19 PM, Weber
>> Hi all,
>> Question: How much processing power to get real time
>> RTK corrections from RTKLib?
>> I'm thinking of using uBlox LEA-6T-0 (5 Hz RAW
>> update) on both basestation and rover (a UAV), with
>> RTKNAVI or an adaptation running on the rover so I
>> need to choose a onboard computer capable.
>> Thanks,
>> Weber
>> This message is sent to you from
>> FOSS-GPS at lists.osgeo.org
>> <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>> Visit
>> http://lists.osgeo.org/mailman/listinfo/foss-gps to
>> manage your subscription
>> For more information, check
>> http://wiki.osgeo.org/wiki/FOSS-GPS
>> This message is sent to you fromFOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>> Visithttp://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>> For more information, checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from FOSS-GPS at lists.osgeo.org
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to
> Weber de Souza Calixto
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
> your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131003/76c17c37/attachment-0001.html>
More information about the FOSS-GPS
