[FOSS-GPS] High SNR Satellites not being used
Sean Hyde
sean.a.hyde at gmail.com
Wed Sep 24 12:23:43 PDT 2014
Hello Felipe,
Thanks for the response.
In this case, the base station antenna is mounted to a tripod and so not moving. The last screenshot I sent was of the system still in Kinematic mode with the rover inside.
I have repeated the test today (Around 3:20PM Eastern on Sept 24) with the system in Single mode -- only receiving information from the base station.
Today, G05 is tracking but G02 still is not. I have attached a screenshot.
Thanks,
-Sean
From: foss-gps-bounces at lists.osgeo.org [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of Felipe G. Nievinski
Sent: Wednesday, September 24, 2014 3:10 PM
To: foss-gps at lists.osgeo.org
Subject: Re: [FOSS-GPS] High SNR Satellites not being used
Most of the time a satellite set unhealthy by the control segment can still be tracked fine, it's just that its actual orbit is expected not to be as well described by the broadcast ephemerides due to a sudden maneuver.
Also, you didn't mention if the data were being processed in point positioning; in relative positioning, a satellite has to be visible from both stations (rover and base) to be usable.
-F.
Message: 2
Date: Tue, 23 Sep 2014 16:43:02 -0400
From: "Sean Hyde" <sean.a.hyde at gmail.com <mailto:sean.a.hyde at gmail.com> >
To: "'Open Source GPS-related discussion and support'"
<foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org> >
Message-ID: <02c001cfd76e$f8b1ccd0$ea156670$@gmail.com <http://gmail.com> >
Content-Type: text/plain; charset="utf-8"
That?s a great resource!
Unfortunately, the period was approx. 12-4PM on Sept 23, 2014 (Eastern US) and 06 is actually tracking OK. 02, 05 and 25 are all showing 50 dBHz and yet not being used. Very strange.
-Sean
From: foss-gps-bounces at lists.osgeo.org <mailto:foss-gps-bounces at lists.osgeo.org> [mailto:foss-gps-bounces at lists.osgeo.org <mailto:foss-gps-bounces at lists.osgeo.org> ] On Behalf Of Felipe G. Nievinski
Sent: Tuesday, September 23, 2014 4:39 PM
To: foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>
Maybe PRN06 was set unhealthy?
You didn't mention the tracking period.
Check the NANUs, e.g.:
<http://celestrak.com/GPS/NANU/2014/nanu.2014057.txt>
CONDITION: GPS SATELLITE SVN67 (PRN06) WAS UNUSABLE ON JDAY 198 (17 JUL 2014) BEGINNING 0950 ZULU UNTIL JDAY 198 (17 JUL 2014) ENDING 1507 ZULU.
Historical outages here:
<http://adn.agi.com/SatelliteOutageCalendar/GPSHistoricalOutages.aspx>
-F.
Message: 1
Date: Tue, 23 Sep 2014 16:00:05 -0400
From: "Sean Hyde" <sean.a.hyde at gmail.com <mailto:sean.a.hyde at gmail.com> <mailto:sean.a.hyde at gmail.com <mailto:sean.a.hyde at gmail.com> > >
To: <foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org> <mailto:foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org> > >
Subject: [FOSS-GPS] High SNR Satellites not being used
Message-ID: <02ac01cfd768$f8740f40$e95c2dc0$@gmail.com <http://gmail.com> <http://gmail.com> >
Content-Type: text/plain; charset="us-ascii"
Hey Guys,
I noticed today that despite some satellites having >40 dBHz (as reported in
RTKNavi), they are not green and are not being used. They are also not
marked as 'OK' in the RTKMonitor. Any idea why? I do not have any
specifically excluded in the 'Options' settings and I have the Elevation
Mask set to zero.
I've attached a screenshot of the SNR from RTKNavi (the Rover is inside a
building so that's why it is so low, but the base station is outside).
Thanks,
-Sean
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140923/3d1b4cba/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140923/3d1b4cba/attachment.png>
FOSS-GPS mailing list
FOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org> <mailto:FOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org> >
http://lists.osgeo.org/mailman/listinfo/foss-gps
End of FOSS-GPS Digest, Vol 68, Issue 14
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140923/dab036a5/attachment-0001.html>
End of FOSS-GPS Digest, Vol 68, Issue 15
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140924/58fb507a/attachment-0001.html>
Name: High SNR Single.PNG
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140924/58fb507a/attachment-0001.png>
More information about the FOSS-GPS
