[gdal-dev] tiff support: internal or external?
Andreas Neumann a.neumann at carto.net
Mon Sep 1 13:43:40 EDT 2008
Thank you for the clarification, Frank.
Yes, I am using the latest versions of the libraries. Good to know that
with the internal option I do not have to install the external
libtiff/libgeotiff libraries.
Andreas
Frank Warmerdam wrote:
> Andreas Neumann wrote:
>> Hi,
>> I am wondering what are the pros and cons of using tiff support from
>> internal or external (libtiff, libgeotiff). Are there any limitations
>> with
>> either approach? I am specifically wondering about the consequences with
>> the bigtiff support. Do both approaches support bigtiff if I use the most
>> recent versions?
>> Thanks for any hints on what is the better option.
> Andreas,
> I think internal and external libtiff+libgeotiff should be equivelent
> as long as you are essentially using "cvs head" of libtiff and libgeotiff.
> So, the internal copies are generally there for convenient building, but
> if you are preparing complex binaries then using external copies of libtiff
> and libgeotiff may be more appropriate, such as I do with OSGeo4W and
> FWTools.
> Best regards,
Andreas Neumann
Böschacherstrasse 6
CH-8624 Grüt (Gossau ZH)
Switzerland
Phone: ++41-44-2736668
Email: a.neumann at carto.net
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
