[gdal-dev] Ninjo tiff tags
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Jun 16 09:59:53 EDT 2010
Martin,
GDAL cannot the tags you want in the tiff file.
You may be able to set the tags using tiffset or some other application
through python. (my two cents)
On Wed, Jun 16, 2010 at 6:53 PM, Martin Raspaud <martin.raspaud at smhi.se>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Chaitanya kumar CH skrev:
> > Martin,
> > Please provide more details. What was the error message.
> > Refer to
> > (http://trac.osgeo.org/gdal/browser/trunk/autotest/gcore/tiff_write.py)
> > for examples.
> > The metadata items are stored according to the profile used.
> > (http://gdal.org/frmt_gtiff.html)
> Hi,
> thanks for the info.
> Unfortunately this is not relevant to our situation. We are looking to
> write
> specific custom tiff tags in the file, tags of which we know the name, the
> type,
> the id number and the value.
> For example the tag
> NTD_Magic
> which has 40000 as Id number, is an ascii field and hold "MAGIC" as value.
> Using the standard setmetadata function in gdal writes the tag inside this
> xml
> GDALinfo object, which is not what we want...
> Martin
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org/
> iQEcBAEBAgAGBQJMGNBEAAoJEBdvyODiyJI48YIIAMN+u7WCEusWhTajYnmY8xVX
> 8qpyT6mmvYKLO/YsCh0a9ffygOy0C3louRgT/Z+FMLu2qZTQvbRtPu9yD7T0MrOt
> k4U8pxyWR4YyR4JJWhgUqr01/trdVnKCiUAtLWEScK9wzfYSVP7XNSZh709sHIYS
> fGy5PfdWF0WNnbov5HWmfaefAhL+4J0u0381hxrvbgZL6++UlAIUlKjiKEUeAYoz
> Ixl4wWOGwMvUFUPeeiYc0JzGRduGBoiqynQEi1udojcjdRr0iB61AqvlXtrGsn/2
> Ai3rYJ+b4e37YPREwSRJowrg33hYt8MPjSjHr2awIRHIfqBYotthfGD7hlMm76s=
> =4yFP
> -----END PGP SIGNATURE-----
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100616/c9e7c8a2/attachment-0001.html
