[gdal-dev] RFC 73 (aka gdalsrsbarn) available for review
Andrew Bell andrew.bell.ia at gmail.com
Thu Jan 17 11:38:13 PST 2019
On Thu, Jan 17, 2019 at 2:09 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 17 janvier 2019 13:45:27 CET Andrew Bell wrote:
> > What is the logic behind the PROJ symbol renaming?
> First, it is purely optional and require active decision of the user to
> build
> PROJ that way. This is only meant to be used by people wanting to mix GDAL
> master + PROJ master + GDAL dependencies built with against old PROJ
> version.
> This is useful in particular for CI purposes where I want to be able to
> pull
> GDAL dependencies built against PROJ 4.9.x.
> This is meant at managing the transition before all the stack is built
> against
> PROJ 6
I guess this just sounds like a development/test issue rather than
something that should be exposed for users.
> I remember terrible
> > things about previous symbol renaming efforts.
> Really ? Well, they eventually "solved" quite severe issues during the
> libtiff
> 3 -> 4 transition.
I remember hitting a GDAL with statically-linked libtiff that had renamed
symbols or some such.  It caused problems.
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190117/b3ca2f91/attachment.html>
