[Geomoose-users] GM 1.6 Identify subset of layer features
    Brent Fraser
    bfraser at geoanalytic.com
    Wed Dec  1 12:31:41 EST 2010
Brian,
   Couldn't you just use the same layer definition in your identify.map
as you use in your display layer?
Best Regards,
Brent Fraser
On 12/1/2010 8:53 AM, Brian Welch wrote:
> I'm using Geomoose v1.6
> I have a layer in my application that shows a subset of parcels (local
> college-owned land). The mapping layer in GM uses a simple expression
> based on the property owner's name to map just those properties owned
> by the colleges.
> I'd like to create an appropriate layer in the Identify.map file that
> will act only on that subset in order to display specific information
> related to the colleges. However, I don't want the college information
> to show up for all parcels in town. Is there some way to replicate the
> expression that I use in the CLASS call of the mapping file to get the
> LAYER in the Identify.map file to act only the college-owned parcels?
> I can't figure out whether the qstring_validation_pattern is where I
> should focus, and if so, what is the appropriate query syntax? The
> field name is [DEEDHOLD] and the query value would be "*COLLEGE" (note
> the need for a wildcard to pick up both colleges in town).
> I'd like to know if this is possible by modifying the Identify.map
> layer with an appropriate query or whether I should just take the easy
> way out and create a separate shapefile of college-owned parcels.
> Thanks.
> Brian
> Brian Welch, GIS Technician
> City of Northfield
> Northfield, MN 55057
> 507-645-3027
> Increase Visibility of Your 3D Game App&  Earn a Chance To Win $500!
> Tap into the largest installed PC base&  get more eyes on your game by
> optimizing for Intel(R) Graphics Technology. Get started today with the
> Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
> http://p.sf.net/sfu/intelisp-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101201/46995d96/attachment.html
More information about the Geomoose-users
