[Geomoose-users] GeoMoose for total neophytes
Anderson, Dean anderson.dean at co.polk.or.us
Fri Oct 12 08:19:24 PDT 2012
When testing/starting with 2.6 I found it best to add a layer or two of my
own to the demo.  Then add an extent for your data set in the zoomto
section of the mapbook.xml file.  That way you can bring up the demo and
zoom to your area to see how your stuff looks.   Many of the background
layers are world-wide so you can also see other layers (yahoo, google,
etc.) as well.  That way your not taking too much on right away.
Good luck
Dean R Anderson
IT Director
Polk County
On Thu, Oct 11, 2012 at 2:05 PM, Brian Fischer <bfischer at houstoneng.com>wrote:
>  My suggestion is to project a few of your layers to web Mercator and try
> to get those working first.  That is what the demo is setup in.****
> Then start to work through changing your projection.  This page might help
> as well.   http://geomoose.org/trunk/docs/projections.html ****
> The pink screen though is probably related to a syntax problem or path
> problem in your map file though.****
> *Brian Fischer, CFM*
> Principal | GIS Project Manager ****
> Houston Engineering, Inc.****
> *O* 763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Jason Menard
> *Sent:* Thursday, October 11, 2012 2:47 PM
> *To:* Basques, Bob (CI-StPaul)
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] GeoMoose for total neophytes****
> Hi Bob,****
> Nope, we're doing this in NY State Plane East on NAD83-- EPSG2905.  I have
> the projection files in the appropriate bins-- Firebug isn't throwing any
> exceptions looking for projections.****
> Would it be better to try to testbed things for learning purposes in
> Minnesota rather than try to change every extent and projection for upstate
> New York?  I have a ton of my own MN data to test with, but when you're
> just editing the mapbook, things seem pretty straightforward to alter, yet
> on anything but the demo, GM is quite borked.  I keep thinking I'm missing
> something fundamentally obvious that I'm just too ignorant to know is
> obvious...****
> Thanks!****
> Best,****
> Jason****
> Jason Menard
> menard.jason at gmail.com
> On Thu, Oct 11, 2012 at 3:29 PM, Basques, Bob (CI-StPaul) <
> bob.basques at ci.stpaul.mn.us> wrote:****
> First of all, are you using the same projection as the demo for your own
> data?****
> Bobb****
> *Sent:* Thursday, October 11, 2012 2:20 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] GeoMoose for total neophytes****
> Hi all,****
> I've got GeoMoose installed on a Windows Server 2008 testbed and the demo
> working.  But every attempt at actually getting my own data in or changing
> the projection results in a pink screen.  I think I've got the mapbook.xml
> figured out (though sometimes how GeoMoose handles extent units confuses
> me) and I'm starting to get a grasp of how things are working, but I just
> can't get it to work!  I think if I get some success on any one issue, the
> rest of the problems will solve themselves, but I'm having trouble getting
> to that first success.  I know my way around GIS, but this is my first
> attempt at web-delivered data.****
> Help!****
> Best,****
> Jason
> Jason Menard
> menard.jason at gmail.com****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121012/8512c0ab/attachment-0001.html>
More information about the Geomoose-users mailing list
