[GeoNode-devel] [GeoNode-users] Installing SSL certificates in GeoNode
Dimitris Karakostis
karakostis.dimitris at gmail.com
Thu Jun 15 06:33:06 PDT 2017
I figured out that the issue was related with doublicated links in the
base_link table. Apparently when I executed the updatelayer function new
links (with https) were created but the old ones were not deleted. This
later was causing conflict when the layer_detail page was loading.
Regarding installing the SSL in nginx server I followed this tutorial:
https://goo.gl/Iod9kQ
Dimitris
On Thu, Jun 15, 2017 at 11:10 AM, Amedeo Fadini <amefad at gmail.com> wrote:
> Hi Dimitris,
> How is handled the Proxy configuration in Nginx?
> Did you checked if the proxy_pass in Nginx is mapped to the same address
> and port of <connector port> in tomcat7/server.xml?
> If you can add the part of Nginx configuration to the tutorial page i
> think it will be good.
> Amefad
> 2017-06-15 8:40 GMT+02:00 Dimitris Karakostis <
> karakostis.dimitris at gmail.com>:
>> Hey list,
>> We are installing SSL certificates for our GeoNode instance. I am
>> testing right now in staging and I am facing some issues. Although the SSL
>> is installed in the server and partially works, I am not able to load the
>> existing layers.
>> To install the SSL I have followed the instructions here:
>> http://docs.geonode.org/en/master/tutorials/advanced/g
>> eonode_production/ssl.html (instead of apache we have nginx)
>> I have also changed the corresponding URLs in the local_settings.py file
>> (SITE_URL etc.)
>> And I have executed the updatelayers command.
>> The staging.geonode.wfp.org page loads with an https and a notification
>> that is not fully secured. This must be cause some images and the
>> openstreetmap baselayer have hardcoded http instead of https.
>> I can upload new layers and style them or edit the metadata but I am not
>> able to access any of the old (existing) layers.
>> I get a NGINX 502 Bad Gateway error. The log files are not particularly
>> helpful. I suspect that some of the links broke after I executed the
>> updatelayer command. Before that, I was able to access the layers but I
>> couldn't style or edit the metadata.
>> Do you have any idea what it could be the issue?
>> Thanks a lot.
>> Dimitris
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170615/9d2b144d/attachment-0001.html>
More information about the geonode-devel
