[GeoNode-devel] Fwd: [GeoNode-users] GWC doesn't work on docker Geonode 2.10 master
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Dec 17 01:04:51 PST 2018
---------- Forwarded message ---------
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Date: lun 17 dic 2018 alle ore 10:04
Subject: Fwd: [GeoNode-users] GWC doesn't work on docker Geonode 2.10 master
To: geonode-users <geonode-users at lists.osgeo.org>
Following a recent discussion on GeoWebCache tile caching issues, here
below the steps to enable them for the default GeoNode SRS (EPSG:3857).
I will work on the next days to persist this on the GeoServer WAR Data Dir,
but for whom don't want to update GeoServer and/or need to simply enable it
for their existing installation, just follow the simple instructions here
below.
In the meantime I'll send to you a couple of recordings showing how to
create and set a new GWC gridset.
Would it be possible for you to do a quick test on your environment? Can
you also send me feedbacks on the outcomes?
If this fixes the issue, I can make the configuration persistent on
GeoServer, so that the users won't need to create the gridsets by
themselves.
Thanks for your help.
A.
1)
[image: gwc-gridsets.gif]
2)
[image: gwc-layer-tiles-defaults.gif]
Il giorno ven 14 dic 2018 alle ore 17:01 Dejan Samardzic <
dejan.samardzic at cedis.me> ha scritto:
> Hi Alessio,
> Thanks, I'm waiting for your answer.
> Regards.
> Dejan
> Sent from my Samsung Galaxy smartphone.
> -------- Original message --------
> Date: 14/12/2018 4:32 pm (GMT+01:00)
> To: Dejan Samardzic <dejan.samardzic at cedis.me>
> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Subject: Re: [GeoNode-users] GWC doesn't work on docker Geonode 2.10
> master
> Hello Dejan,
> so, the requests seem correct, except maybe for one thing. I see those are
> using SRS=EPSG:3857 ... it is possible that GWC cannot find the correct
> gridset on Geoserver.
> I'm going to do a quick test locally. It might be just an incomplete
> GeoServer config.
> Will let you know ASAP.
> Il giorno ven 14 dic 2018 alle ore 16:23 Dejan Samardzic <
>> Dear Alessio,
>> please find wms get requests in the attachment.
>> regards,
>> Dejan.
>> On 12/14/2018 3:29 PM, Alessio Fabiani wrote:
>> Hello Dejan,
>> could you send to me (in private email) some of the tiled OWS GetMap
>> requests you are seeing on the browser?
>> Il giorno ven 14 dic 2018 alle ore 15:14 Dejan Samardzic <
>>> Dear Geonode community,
>>> We have made docker Gonode 2.10 master branch installation on Ubuntu
>>> 18.04 by Alessio's guide:
>>> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY/edit
>>> after that we have configure GeoWebCache:
>>> 1) We have configure Caching to external postgresql database:
>>> Tile caching - Disk quota....Enable disk Quota ....Maximum tile cache
>>> size 50GiB
>>> Disk quota check frequency:600s
>>> Disk quota store type....External database
>>> Target database type....PostgreSQL
>>> JDBC data source...GeoServer managed connection pool
>>> JDBC Driver class name.....org.postgresql.Driver
>>> JDBC connection URL.....jdbc:postgresql://localhost:5432/geonode
>>> User name.....geonode
>>> Password.....****
>>> Validation query.....select 1
>>> 2) Define path for cache
>>> From geoserver container:
>>> mkdir /var/cache/geoserver
>>> chmod -R 777 geoserver
>>> vi /usr/local/tomcat/webapps/geoserver/WEB-INF/web.xml
>>> insert :
>>> <context-param>
>>> <param-name>GEOWEBCACHE_CACHE_DIR</param-name>
>>> <param-value>/var/cache/geoserver/</param-value>
>>> </context-param>
>>> Now seeding of GeoWebCache is working and creating png files in
>>> /var/cache/geoserver.
>>> But GeoWebCache is not working. When we browse new layer it doesn't
>>> create png files in /var/cache/geoserver. Also, already created png files
>>> (using Seeding of GeoWebCash) are not delivered form cache.
>>> Please watch for yourself about layer
>>> novi_novi_r6_Ivanje_10kV_izmijenjen:
>>> https://www.youtube.com/watch?v=SgyJw7mjXaU
>>> regards,
>>> Dejan Samardzic
>>> * Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
>>> CEDIS d.o.o.
>>> Ivana Milutinovića 12, 81000 Podgorica
>>> gsm: +382 67 220 971
>>> tel: +382 20 408 453
>>> email: dejan.samardzic at cedis.me
>>> web: www.cedis.me
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
>> @alfa7691 Founder/Technical Lead
>> GeoSolutions S.A.S. Via di Montramito 3/A - 55054 Massarosa (LU) - Italy phone:
>> +39 0584 962313 fax: +39 0584 1660272 mob: +39 331 6233686
>> http://www.geo-solutions.it http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> CEDIS d.o.o.
>> web: www.cedis.me
> @alfa7691
> GeoSolutions S.A.S.
> phone: +39 0584 962313
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
@alfa7691
GeoSolutions S.A.S.
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181217/31398aab/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181217/31398aab/attachment-0001.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181217/31398aab/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181217/31398aab/attachment-0003.gif>
More information about the geonode-devel
