[GeoNode-devel] Issue with the search
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 9 06:22:27 PDT 2019
Uhm,
so the issue should not be related to some security constraints.
Can you maybe check if there's some Javascript error around?
What is the number reported by the layers count?
Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> With the superuser as well.
> P.
> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Paolo,
>> is this happening with the superuser also? Or just with some users?
>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>> Dear all,
>>> I have a couple of the latest GeoNode 2.10.x installed with Docker that
>>> have the same issue.
>>> In the layers page only the last 2 modified layers are listed while in
>>> the filter under the "Type" nav I have the correct number of existing
>>> layers in the db.
>>> The GeoFence permissions look good.
>>> Any idea of what is causing the problem of omitting all published layers
>>> except the last 2?
>>> Thanks.
>>> Bye,
>>> Paolo
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/2ecc287a/attachment-0001.html>
More information about the geonode-devel mailing list
