[GeoNode-devel] Issue with the search
Paolo Pasquali
paolo.pasquali at gmail.com
Tue Apr 9 06:40:59 PDT 2019
No javascript error (except it can't find leaflet-src.js.map)
But here is a list of issues (I'm finding more).
- The layers count corresponds to the number of listed layers but it is
different from what is reported in the filter type.
- The username does not appear in the resourcebase_snippet and points to a
broken url (/layers/people/profile/username?!?)
- The icon (e.g. vector data) before the layer name does not appear (no
error though)
- By adding more layers now the count is not limited to 2 anymore (maybe I
made something different but can't figure out what). Anyway, old layers are
not listed yet.
Thanks,
P.
On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Uhm,
> so the issue should not be related to some security constraints.
> Can you maybe check if there's some Javascript error around?
> What is the number reported by the layers count?
> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Ciao Alessio,
>> With the superuser as well.
>> P.
>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>> Hello Paolo,
>>> is this happening with the superuser also? Or just with some users?
>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>> Dear all,
>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker that
>>>> have the same issue.
>>>> In the layers page only the last 2 modified layers are listed while in
>>>> the filter under the "Type" nav I have the correct number of existing
>>>> layers in the db.
>>>> The GeoFence permissions look good.
>>>> Any idea of what is causing the problem of omitting all published
>>>> layers except the last 2?
>>>> Thanks.
>>>> Bye,
>>>> Paolo
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/0d7f8617/attachment-0001.html>
More information about the geonode-devel
