[GeoNode-devel] Issue with the search
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 9 06:50:56 PDT 2019
Uhm it looks like you have some mixed code around.
How did you installed the GeoNodes? Which docker procedures you followed?
Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> No javascript error (except it can't find leaflet-src.js.map)
> But here is a list of issues (I'm finding more).
> - The layers count corresponds to the number of listed layers but it is
> different from what is reported in the filter type.
> - The username does not appear in the resourcebase_snippet and points to a
> broken url (/layers/people/profile/username?!?)
> - The icon (e.g. vector data) before the layer name does not appear (no
> error though)
> - By adding more layers now the count is not limited to 2 anymore (maybe I
> made something different but can't figure out what). Anyway, old layers are
> not listed yet.
> Thanks,
> P.
> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Uhm,
>> so the issue should not be related to some security constraints.
>> Can you maybe check if there's some Javascript error around?
>> What is the number reported by the layers count?
>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>> Ciao Alessio,
>>> With the superuser as well.
>>> P.
>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>> Hello Paolo,
>>>> is this happening with the superuser also? Or just with some users?
>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>> Dear all,
>>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker
>>>>> that have the same issue.
>>>>> In the layers page only the last 2 modified layers are listed while in
>>>>> the filter under the "Type" nav I have the correct number of existing
>>>>> layers in the db.
>>>>> The GeoFence permissions look good.
>>>>> Any idea of what is causing the problem of omitting all published
>>>>> layers except the last 2?
>>>>> Thanks.
>>>>> Bye,
>>>>> Paolo
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/bed20da8/attachment-0001.html>
More information about the geonode-devel mailing list
