[GeoNode-devel] Issue with the search
Paolo Pasquali
paolo.pasquali at gmail.com
Tue Apr 9 07:14:40 PDT 2019
Used geonode-project:
https://github.com/GeoNode/geonode-project#start-your-server
On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Uhm it looks like you have some mixed code around.
> How did you installed the GeoNodes? Which docker procedures you followed?
> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> No javascript error (except it can't find leaflet-src.js.map)
>> But here is a list of issues (I'm finding more).
>> - The layers count corresponds to the number of listed layers but it is
>> different from what is reported in the filter type.
>> - The username does not appear in the resourcebase_snippet and points to
>> a broken url (/layers/people/profile/username?!?)
>> - The icon (e.g. vector data) before the layer name does not appear (no
>> error though)
>> - By adding more layers now the count is not limited to 2 anymore (maybe
>> I made something different but can't figure out what). Anyway, old layers
>> are not listed yet.
>> Thanks,
>> P.
>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>> Uhm,
>>> so the issue should not be related to some security constraints.
>>> Can you maybe check if there's some Javascript error around?
>>> What is the number reported by the layers count?
>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>> Ciao Alessio,
>>>> With the superuser as well.
>>>> P.
>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>> Hello Paolo,
>>>>> is this happening with the superuser also? Or just with some users?
>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>> Dear all,
>>>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker
>>>>>> that have the same issue.
>>>>>> In the layers page only the last 2 modified layers are listed while
>>>>>> in the filter under the "Type" nav I have the correct number of existing
>>>>>> layers in the db.
>>>>>> The GeoFence permissions look good.
>>>>>> Any idea of what is causing the problem of omitting all published
>>>>>> layers except the last 2?
>>>>>> Thanks.
>>>>>> Bye,
>>>>>> Paolo
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/b6a19d6e/attachment-0001.html>
More information about the geonode-devel
