[GeoNode-devel] Issue with the search
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Apr 9 07:19:03 PDT 2019
Ok, let me give it a try. If the issue is confirmed I will open a ticket on
Github.
Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Used geonode-project:
> https://github.com/GeoNode/geonode-project#start-your-server
> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Uhm it looks like you have some mixed code around.
>> How did you installed the GeoNodes? Which docker procedures you followed?
>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>> No javascript error (except it can't find leaflet-src.js.map)
>>> But here is a list of issues (I'm finding more).
>>> - The layers count corresponds to the number of listed layers but it is
>>> different from what is reported in the filter type.
>>> - The username does not appear in the resourcebase_snippet and points to
>>> a broken url (/layers/people/profile/username?!?)
>>> - The icon (e.g. vector data) before the layer name does not appear (no
>>> error though)
>>> - By adding more layers now the count is not limited to 2 anymore (maybe
>>> I made something different but can't figure out what). Anyway, old layers
>>> are not listed yet.
>>> Thanks,
>>> P.
>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>> Uhm,
>>>> so the issue should not be related to some security constraints.
>>>> Can you maybe check if there's some Javascript error around?
>>>> What is the number reported by the layers count?
>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>> Ciao Alessio,
>>>>> With the superuser as well.
>>>>> P.
>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>> Hello Paolo,
>>>>>> is this happening with the superuser also? Or just with some users?
>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>> Dear all,
>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker
>>>>>>> that have the same issue.
>>>>>>> In the layers page only the last 2 modified layers are listed while
>>>>>>> in the filter under the "Type" nav I have the correct number of existing
>>>>>>> layers in the db.
>>>>>>> The GeoFence permissions look good.
>>>>>>> Any idea of what is causing the problem of omitting all published
>>>>>>> layers except the last 2?
>>>>>>> Thanks.
>>>>>>> Bye,
>>>>>>> Paolo
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/29d3d42a/attachment-0001.html>
More information about the geonode-devel
