[GeoNode-devel] Issue with the search
Paolo Pasquali
paolo.pasquali at gmail.com
Tue Apr 9 07:33:33 PDT 2019
Thank you.
I'm trying again with a fresh installation.
P.
On Tue, Apr 9, 2019 at 4:19 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Ok, let me give it a try. If the issue is confirmed I will open a ticket
> on Github.
> Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Used geonode-project:
>> https://github.com/GeoNode/geonode-project#start-your-server
>> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
>>> Uhm it looks like you have some mixed code around.
>>> How did you installed the GeoNodes? Which docker procedures you followed?
>>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>>> No javascript error (except it can't find leaflet-src.js.map)
>>>> But here is a list of issues (I'm finding more).
>>>> - The layers count corresponds to the number of listed layers but it is
>>>> different from what is reported in the filter type.
>>>> - The username does not appear in the resourcebase_snippet and points
>>>> to a broken url (/layers/people/profile/username?!?)
>>>> - The icon (e.g. vector data) before the layer name does not appear (no
>>>> error though)
>>>> - By adding more layers now the count is not limited to 2 anymore
>>>> (maybe I made something different but can't figure out what). Anyway, old
>>>> layers are not listed yet.
>>>> Thanks,
>>>> P.
>>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>>> Uhm,
>>>>> so the issue should not be related to some security constraints.
>>>>> Can you maybe check if there's some Javascript error around?
>>>>> What is the number reported by the layers count?
>>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>>> Ciao Alessio,
>>>>>> With the superuser as well.
>>>>>> P.
>>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>>> Hello Paolo,
>>>>>>> is this happening with the superuser also? Or just with some users?
>>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>>> Dear all,
>>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker
>>>>>>>> that have the same issue.
>>>>>>>> In the layers page only the last 2 modified layers are listed while
>>>>>>>> in the filter under the "Type" nav I have the correct number of existing
>>>>>>>> layers in the db.
>>>>>>>> The GeoFence permissions look good.
>>>>>>>> Any idea of what is causing the problem of omitting all published
>>>>>>>> layers except the last 2?
>>>>>>>> Thanks.
>>>>>>>> Bye,
>>>>>>>> Paolo
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax: +39 0584 1660272
>>>>>>> mob: +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/35eb7e13/attachment-0001.html>
More information about the geonode-devel
