[GeoNode-devel] Issue with the search
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 9 07:48:20 PDT 2019
Paolo,
in the meantime, could you maybe try to disable the HAYSTACK_SEARCH ?
Il giorno mar 9 apr 2019 alle ore 16:33 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Thank you.
> I'm trying again with a fresh installation.
> P.
> On Tue, Apr 9, 2019 at 4:19 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Ok, let me give it a try. If the issue is confirmed I will open a ticket
>> on Github.
>> Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
>>> Used geonode-project:
>>> https://github.com/GeoNode/geonode-project#start-your-server
>>> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
>>>> Uhm it looks like you have some mixed code around.
>>>> How did you installed the GeoNodes? Which docker procedures you
>>>> followed?
>>>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>>>> No javascript error (except it can't find leaflet-src.js.map)
>>>>> But here is a list of issues (I'm finding more).
>>>>> - The layers count corresponds to the number of listed layers but it
>>>>> is different from what is reported in the filter type.
>>>>> - The username does not appear in the resourcebase_snippet and points
>>>>> to a broken url (/layers/people/profile/username?!?)
>>>>> - The icon (e.g. vector data) before the layer name does not appear
>>>>> (no error though)
>>>>> - By adding more layers now the count is not limited to 2 anymore
>>>>> (maybe I made something different but can't figure out what). Anyway, old
>>>>> layers are not listed yet.
>>>>> Thanks,
>>>>> P.
>>>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>>>> Uhm,
>>>>>> so the issue should not be related to some security constraints.
>>>>>> Can you maybe check if there's some Javascript error around?
>>>>>> What is the number reported by the layers count?
>>>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>>>> Ciao Alessio,
>>>>>>> With the superuser as well.
>>>>>>> P.
>>>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>>>> Hello Paolo,
>>>>>>>> is this happening with the superuser also? Or just with some users?
>>>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>>>> Dear all,
>>>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with Docker
>>>>>>>>> that have the same issue.
>>>>>>>>> In the layers page only the last 2 modified layers are listed
>>>>>>>>> while in the filter under the "Type" nav I have the correct number of
>>>>>>>>> existing layers in the db.
>>>>>>>>> The GeoFence permissions look good.
>>>>>>>>> Any idea of what is causing the problem of omitting all published
>>>>>>>>> layers except the last 2?
>>>>>>>>> Thanks.
>>>>>>>>> Bye,
>>>>>>>>> Paolo
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>> phone: +39 0584 962313
>>>>>>>> fax:     +39 0584 1660272
>>>>>>>> mob:   +39 331 6233686
>>>>>>>> http://www.geo-solutions.it
>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/0f04bbdc/attachment-0001.html>
More information about the geonode-devel mailing list
