[GeoNode-devel] Issue with the search
Paolo Pasquali
paolo.pasquali at gmail.com
Tue Apr 9 07:57:35 PDT 2019
Oh, wait! That's the HAYSTACK_SEARCH!
If I set it to False, everything seems fine.
On Tue, Apr 9, 2019 at 4:48 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Paolo,
> in the meantime, could you maybe try to disable the HAYSTACK_SEARCH ?
> Il giorno mar 9 apr 2019 alle ore 16:33 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Thank you.
>> I'm trying again with a fresh installation.
>> P.
>> On Tue, Apr 9, 2019 at 4:19 PM Alessio Fabiani <
>>> Ok, let me give it a try. If the issue is confirmed I will open a ticket
>>> on Github.
>>> Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
>>>> Used geonode-project:
>>>> https://github.com/GeoNode/geonode-project#start-your-server
>>>> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
>>>>> Uhm it looks like you have some mixed code around.
>>>>> How did you installed the GeoNodes? Which docker procedures you
>>>>> followed?
>>>>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>>>>> No javascript error (except it can't find leaflet-src.js.map)
>>>>>> But here is a list of issues (I'm finding more).
>>>>>> - The layers count corresponds to the number of listed layers but it
>>>>>> is different from what is reported in the filter type.
>>>>>> - The username does not appear in the resourcebase_snippet and points
>>>>>> to a broken url (/layers/people/profile/username?!?)
>>>>>> - The icon (e.g. vector data) before the layer name does not appear
>>>>>> (no error though)
>>>>>> - By adding more layers now the count is not limited to 2 anymore
>>>>>> (maybe I made something different but can't figure out what). Anyway, old
>>>>>> layers are not listed yet.
>>>>>> Thanks,
>>>>>> P.
>>>>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>>>>> Uhm,
>>>>>>> so the issue should not be related to some security constraints.
>>>>>>> Can you maybe check if there's some Javascript error around?
>>>>>>> What is the number reported by the layers count?
>>>>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>>>>> Ciao Alessio,
>>>>>>>> With the superuser as well.
>>>>>>>> P.
>>>>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>>>>> Hello Paolo,
>>>>>>>>> is this happening with the superuser also? Or just with some users?
>>>>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>>>>> Dear all,
>>>>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with
>>>>>>>>>> Docker that have the same issue.
>>>>>>>>>> In the layers page only the last 2 modified layers are listed
>>>>>>>>>> while in the filter under the "Type" nav I have the correct number of
>>>>>>>>>> existing layers in the db.
>>>>>>>>>> The GeoFence permissions look good.
>>>>>>>>>> Any idea of what is causing the problem of omitting all published
>>>>>>>>>> layers except the last 2?
>>>>>>>>>> Thanks.
>>>>>>>>>> Bye,
>>>>>>>>>> Paolo
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> Founder/Technical Lead
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>> phone: +39 0584 962313
>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>> mob: +39 331 6233686
>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/6a148333/attachment-0001.html>
More information about the geonode-devel
