[GeoNode-devel] Issue with the search
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Apr 9 08:01:38 PDT 2019
Uhm, I see.
I faced a similar issue some time ago. It was caused by some
incompatibility between the elasticsearch server version and the python
libraries.
Since those have been updated recently, it looks like they are causing
issues again :(
I will disable the Hystack search on geonode-project and open a regression
issue accordingly.
Il giorno mar 9 apr 2019 alle ore 16:57 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Oh, wait! That's the HAYSTACK_SEARCH!
> If I set it to False, everything seems fine.
> On Tue, Apr 9, 2019 at 4:48 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Paolo,
>> in the meantime, could you maybe try to disable the HAYSTACK_SEARCH ?
>> Il giorno mar 9 apr 2019 alle ore 16:33 Paolo Pasquali <
>>> Thank you.
>>> I'm trying again with a fresh installation.
>>> P.
>>> On Tue, Apr 9, 2019 at 4:19 PM Alessio Fabiani <
>>>> Ok, let me give it a try. If the issue is confirmed I will open a
>>>> ticket on Github.
>>>> Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
>>>>> Used geonode-project:
>>>>> https://github.com/GeoNode/geonode-project#start-your-server
>>>>> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
>>>>>> Uhm it looks like you have some mixed code around.
>>>>>> How did you installed the GeoNodes? Which docker procedures you
>>>>>> followed?
>>>>>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>>>>>> No javascript error (except it can't find leaflet-src.js.map)
>>>>>>> But here is a list of issues (I'm finding more).
>>>>>>> - The layers count corresponds to the number of listed layers but it
>>>>>>> is different from what is reported in the filter type.
>>>>>>> - The username does not appear in the resourcebase_snippet and
>>>>>>> points to a broken url (/layers/people/profile/username?!?)
>>>>>>> - The icon (e.g. vector data) before the layer name does not appear
>>>>>>> (no error though)
>>>>>>> - By adding more layers now the count is not limited to 2 anymore
>>>>>>> (maybe I made something different but can't figure out what). Anyway, old
>>>>>>> layers are not listed yet.
>>>>>>> Thanks,
>>>>>>> P.
>>>>>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>>>>>> Uhm,
>>>>>>>> so the issue should not be related to some security constraints.
>>>>>>>> Can you maybe check if there's some Javascript error around?
>>>>>>>> What is the number reported by the layers count?
>>>>>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>>>>>> Ciao Alessio,
>>>>>>>>> With the superuser as well.
>>>>>>>>> P.
>>>>>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>>>>>> Hello Paolo,
>>>>>>>>>> is this happening with the superuser also? Or just with some
>>>>>>>>>> users?
>>>>>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>>>>>> Dear all,
>>>>>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with
>>>>>>>>>>> Docker that have the same issue.
>>>>>>>>>>> In the layers page only the last 2 modified layers are listed
>>>>>>>>>>> while in the filter under the "Type" nav I have the correct number of
>>>>>>>>>>> existing layers in the db.
>>>>>>>>>>> The GeoFence permissions look good.
>>>>>>>>>>> Any idea of what is causing the problem of omitting all
>>>>>>>>>>> published layers except the last 2?
>>>>>>>>>>> Thanks.
>>>>>>>>>>> Bye,
>>>>>>>>>>> Paolo
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/b3418340/attachment-0001.html>
More information about the geonode-devel
