[GeoNode-devel] Issue with the search
Paolo Pasquali paolo.pasquali at gmail.com
Tue Apr 9 08:04:20 PDT 2019
Thank you very much.
Ciao
P.
On Tue, Apr 9, 2019 at 5:01 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Uhm, I see.
> I faced a similar issue some time ago. It was caused by some
> incompatibility between the elasticsearch server version and the python
> libraries.
> Since those have been updated recently, it looks like they are causing
> issues again :(
> I will disable the Hystack search on geonode-project and open a regression
> issue accordingly.
> Il giorno mar 9 apr 2019 alle ore 16:57 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Oh, wait! That's the HAYSTACK_SEARCH!
>> If I set it to False, everything seems fine.
>> On Tue, Apr 9, 2019 at 4:48 PM Alessio Fabiani <
>>> Paolo,
>>> in the meantime, could you maybe try to disable the HAYSTACK_SEARCH ?
>>> Il giorno mar 9 apr 2019 alle ore 16:33 Paolo Pasquali <
>>>> Thank you.
>>>> I'm trying again with a fresh installation.
>>>> P.
>>>> On Tue, Apr 9, 2019 at 4:19 PM Alessio Fabiani <
>>>>> Ok, let me give it a try. If the issue is confirmed I will open a
>>>>> ticket on Github.
>>>>> Il giorno mar 9 apr 2019 alle ore 16:14 Paolo Pasquali <
>>>>>> Used geonode-project:
>>>>>> https://github.com/GeoNode/geonode-project#start-your-server
>>>>>> On Tue, Apr 9, 2019 at 3:51 PM Alessio Fabiani <
>>>>>>> Uhm it looks like you have some mixed code around.
>>>>>>> How did you installed the GeoNodes? Which docker procedures you
>>>>>>> followed?
>>>>>>> Il giorno mar 9 apr 2019 alle ore 15:41 Paolo Pasquali <
>>>>>>>> No javascript error (except it can't find leaflet-src.js.map)
>>>>>>>> But here is a list of issues (I'm finding more).
>>>>>>>> - The layers count corresponds to the number of listed layers but
>>>>>>>> it is different from what is reported in the filter type.
>>>>>>>> - The username does not appear in the resourcebase_snippet and
>>>>>>>> points to a broken url (/layers/people/profile/username?!?)
>>>>>>>> - The icon (e.g. vector data) before the layer name does not appear
>>>>>>>> (no error though)
>>>>>>>> - By adding more layers now the count is not limited to 2 anymore
>>>>>>>> (maybe I made something different but can't figure out what). Anyway, old
>>>>>>>> layers are not listed yet.
>>>>>>>> Thanks,
>>>>>>>> P.
>>>>>>>> On Tue, Apr 9, 2019 at 3:22 PM Alessio Fabiani <
>>>>>>>>> Uhm,
>>>>>>>>> so the issue should not be related to some security constraints.
>>>>>>>>> Can you maybe check if there's some Javascript error around?
>>>>>>>>> What is the number reported by the layers count?
>>>>>>>>> Il giorno mar 9 apr 2019 alle ore 15:11 Paolo Pasquali <
>>>>>>>>>> Ciao Alessio,
>>>>>>>>>> With the superuser as well.
>>>>>>>>>> P.
>>>>>>>>>> On Tue, Apr 9, 2019 at 2:39 PM Alessio Fabiani <
>>>>>>>>>>> Hello Paolo,
>>>>>>>>>>> is this happening with the superuser also? Or just with some
>>>>>>>>>>> users?
>>>>>>>>>>> Il giorno mar 9 apr 2019 alle ore 14:25 Paolo Pasquali <
>>>>>>>>>>>> Dear all,
>>>>>>>>>>>> I have a couple of the latest GeoNode 2.10.x installed with
>>>>>>>>>>>> Docker that have the same issue.
>>>>>>>>>>>> In the layers page only the last 2 modified layers are listed
>>>>>>>>>>>> while in the filter under the "Type" nav I have the correct number of
>>>>>>>>>>>> existing layers in the db.
>>>>>>>>>>>> The GeoFence permissions look good.
>>>>>>>>>>>> Any idea of what is causing the problem of omitting all
>>>>>>>>>>>> published layers except the last 2?
>>>>>>>>>>>> Thanks.
>>>>>>>>>>>> Bye,
>>>>>>>>>>>> Paolo
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>> notizia.
>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190409/48395ad9/attachment-0001.html>
More information about the geonode-devel mailing list
