[GeoNode-devel] [GeoNode-users] GeoNode-Project CenTOS7 Installation
1520 gis
juliermeopensourcedeveloper at gmail.com
Wed Jul 17 10:30:31 PDT 2019
Thank you very much Ran, but the issue remains.
mkdir -p /usr/src/app/; \
> source $HOME/.override_env; \
> echo DATABASE_URL=$DATABASE_URL; \
> echo GEODATABASE_URL=$GEODATABASE_URL; \
> echo SITEURL=$SITEURL; \
> echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
> echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION;
DATABASE_URL=postgres://geonode:geonode@db:5432/geonode
GEODATABASE_URL=postgis://geonode_data:geonode_data@db:5432/geonode_data
SITEURL=http://cgticgeo.sipam.gov.br/
ALLOWED_HOSTS=['cgticgeo.sipam.gov.br', 'cgticgeo.sipam.gov.br', '
cgticgeo.sipam.gov.br:80', 'geonode', 'django']
GEOSERVER_PUBLIC_LOCATION=http://cgticgeo.sipam.gov.br/geoserver/
root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -w
geonode -f previsao_meteorologica_aml
JSONField implementation is: <class 'jsonfield.fields.JSONField'>
Inspecting the available layers in GeoServer ...
Found 1 layers, starting processing
Could not retrieve GeoFence Rules count.
... Creating Thumbnail for Layer [geonode:previsao_meteorologica_aml]
Stopping process because --ignore-errors was not set and an error was found.
File "manage.py", line 31, in <module>
execute_from_command_line(sys.argv)
File
"/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
utility.execute()
File
line 346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
"/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
File
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py",
line 124, in handle
execute_signals=True)
File "/usr/src/geonode/geonode/geoserver/helpers.py", line 630, in
gs_slurp
layer.set_permissions(perm_spec)
File "/usr/src/geonode/geonode/security/models.py", line 205, in
set_permissions
sync_geofence_with_guardian(self.layer, perms, user=geofence_user)
File "/usr/src/geonode/geonode/decorators.py", line 48, in wrapper
return func(*args, **kwargs)
File "/usr/src/geonode/geonode/security/utils.py", line 448, in
_update_geofence_rule(layer.name, layer.workspace, service, user=_user)
File "/usr/src/geonode/geonode/security/utils.py", line 592, in
raise RuntimeError(msg)
Exception: ('Failed to process previsao_meteorologica_aml',
RuntimeError('Could not ADD GeoServer User \'admin\' Rule for Layer
u\'previsao_meteorologica_aml\': \'u\'<!doctype html><html
lang="en"><head><title>HTTP Status 404 \\u2013 Not Found</title><style
type="text/css">h1
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
h2
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
h3
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
body
{font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} b
{font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
p
{font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}
a {color:black;} a.name {color:black;} .line
{height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP
Status 404 \\u2013 Not Found</h1><hr class="line" /><p><b>Type</b> Status
Report</p><p><b>Description</b> The origin server did not find a current
representation for the target resource or is not willing to disclose that
one exists.</p><hr class="line" /><h3>Apache
Tomcat/9.0.19</h3></body></html>\'\'',))
Kind regards
Julierme
On Wed, Jul 17, 2019 at 2:23 PM Ran L. <kula009 at gmail.com> wrote:
> Hi Julierme,
> I had the problem you described before. The reason you are getting this is
> because the env variables are not set properly. Run this command before
> running any other commands:
> You should be able to run the commands then.
> I
> On Wed, Jul 17, 2019 at 10:19 AM 1520 gis <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Hi Ran,
>> Thank you very much for your reply. Yes, I just installed a brand new
>> version of GeoNode-Project at 2.8 and updatelayers did not work. See the
>> response in [1]. I then ran
>> python manage.py makemigrations
>> python manage.py migrate
>> However, the problem remains. I am now asked for a superuser [2]. I did
>> create a superuser for GeoNode-Project in a CenTOS7, but did not solve the
>> problem. The issue also happens in GeoNode-Project at 2.10.
>> Any help would be appreciated.
>> Kind regards
>> Julierme
>> [1]
>> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -s
>> metoc -f previsao_meteorologica_aml
>> File
>> utility.execute()
>> File
>> File
>> File
>> File
>> line 98, in handle
>> owner = get_valid_user(user)
>> File "/usr/src/geonode/geonode/people/utils.py", line 44, in
>> get_valid_user
>> theuser = get_default_user()
>> File "/usr/src/geonode/geonode/people/utils.py", line 31, in
>> get_default_user
>> if superusers.count() > 0:
>> File
>> "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line
>> 318, in count
>> return self.query.get_count(using=self.db)
>> File
>> "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py",
>> line 466, in get_count
>> number = obj.get_aggregation(using, ['__count'])['__count']
>> File
>> line 447, in get_aggregation
>> result = compiler.execute_sql(SINGLE)
>> File
>> "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py",
>> line 840, in execute_sql
>> cursor.execute(sql, params)
>> File
>> "/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line
>> 79, in execute
>> return super(CursorDebugWrapper, self).execute(sql, params)
>> File
>> 64, in execute
>> return self.cursor.execute(sql, params)
>> File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line
>> 98, in __exit__
>> six.reraise(dj_exc_type, dj_exc_value, traceback)
>> File
>> 64, in execute
>> File
>> "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py",
>> line 318, in execute
>> return Database.Cursor.execute(self, query, params)
>> django.db.utils.OperationalError: no such table: people_profile
>> [2]
>> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -f
>> File
>> utility.execute()
>> File
>> File
>> File
>> File
>> line 98, in handle
>> get_valid_user
>> File "/usr/src/geonode/geonode/people/utils.py", line 35, in
>> get_default_user
>> raise GeoNodeException('You must have an admin account configured '
>> geonode.GeoNodeException: You must have an admin account configured
>> before importing data. Try: django-admin.py createsuperuser
>> On Wed, Jul 17, 2019 at 2:06 PM Ran L. <kula009 at gmail.com> wrote:
>>> Hello Julierme,
>>> I also had issues with the geonode "updatelayers" command yesterday, and
>>> might have found a possible solution for it:
>>> I'm also using geonode-project with docker on a Ubuntu machine. I
>>> couldn't run the command successfully after building the service. You can
>>> see the details here: https://github.com/GeoNode/geonode/issues/4650
>>> *A fix: *I took my own customized files (templates, python files,
>>> statics, etc.) and dump them into a newly created geonode-project. The
>>> command worked after that.
>>> My speculation is that the geonode-project files I had were not
>>> compatible with the current geonode, since I haven't updated them for a
>>> long while.
>>> Hope this provides some insights.
>>> Thanks!
>>> Ran
>>> On Wed, Jul 17, 2019 at 9:47 AM 1520 gis <
>>>> Dear users and developers,
>>>> I am not sure if it is on the scope of future work, but I have already
>>>> started a tutorial to install GeoNode-Project via Docker on a CentOS7
>>>> server. I got it installed, but not sure that I got all required geonode
>>>> packages on a CenTOS7. Also, I had an issue while using python manage.py
>>>> updatelayers.
>>>> I am making myself a volunteer to help on this theme. I would like to
>>>> share the command lines and have someones' contribution to improve what I
>>>> got so far.
>>>> Kind regards,
>>>> Julierme
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190717/cf3bd48c/attachment.html>
More information about the geonode-devel
