[GeoNode-devel] [GeoNode-users] GeoNode-Project CenTOS7 Installation
Ran L.
kula009 at gmail.com
Wed Jul 17 10:59:09 PDT 2019
But you are getting a different error message this time. Could you try the
simple command:
'django-admin updatelayers'
And see how it goes?
Ran
On Wed, Jul 17, 2019 at 10:30 AM 1520 gis <
juliermeopensourcedeveloper at gmail.com> wrote:
> Thank you very much Ran, but the issue remains.
> mkdir -p /usr/src/app/; \
> > source $HOME/.override_env; \
> > echo DATABASE_URL=$DATABASE_URL; \
> > echo GEODATABASE_URL=$GEODATABASE_URL; \
> > echo SITEURL=$SITEURL; \
> > echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
> > echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION;
> DATABASE_URL=postgres://geonode:geonode@db:5432/geonode
> GEODATABASE_URL=postgis://geonode_data:geonode_data@db:5432/geonode_data
> SITEURL=http://cgticgeo.sipam.gov.br/
> ALLOWED_HOSTS=['cgticgeo.sipam.gov.br', 'cgticgeo.sipam.gov.br', '
> cgticgeo.sipam.gov.br:80', 'geonode', 'django']
> GEOSERVER_PUBLIC_LOCATION=http://cgticgeo.sipam.gov.br/geoserver/
> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -w
> geonode -f previsao_meteorologica_aml
> JSONField implementation is: <class 'jsonfield.fields.JSONField'>
> Inspecting the available layers in GeoServer ...
> Found 1 layers, starting processing
> Could not retrieve GeoFence Rules count.
> ... Creating Thumbnail for Layer [geonode:previsao_meteorologica_aml]
> Stopping process because --ignore-errors was not set and an error was
> found.
> Traceback (most recent call last):
> File "manage.py", line 31, in <module>
> execute_from_command_line(sys.argv)
> File
> "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
> utility.execute()
> File
> line 346, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File
> "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
> line 394, in run_from_argv
> self.execute(*args, **cmd_options)
> File
> line 445, in execute
> output = self.handle(*args, **options)
> File
> "/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py",
> line 124, in handle
> execute_signals=True)
> File "/usr/src/geonode/geonode/geoserver/helpers.py", line 630, in
> gs_slurp
> layer.set_permissions(perm_spec)
> File "/usr/src/geonode/geonode/security/models.py", line 205, in
> set_permissions
> sync_geofence_with_guardian(self.layer, perms, user=geofence_user)
> File "/usr/src/geonode/geonode/decorators.py", line 48, in wrapper
> return func(*args, **kwargs)
> File "/usr/src/geonode/geonode/security/utils.py", line 448, in
> _update_geofence_rule(layer.name, layer.workspace, service,
> user=_user)
> File "/usr/src/geonode/geonode/security/utils.py", line 592, in
> raise RuntimeError(msg)
> Exception: ('Failed to process previsao_meteorologica_aml',
> RuntimeError('Could not ADD GeoServer User \'admin\' Rule for Layer
> u\'previsao_meteorologica_aml\': \'u\'<!doctype html><html
> lang="en"><head><title>HTTP Status 404 \\u2013 Not Found</title><style
> type="text/css">h1
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
> h2
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
> h3
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
> body
> {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} b
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
> p
> {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}
> a {color:black;} a.name {color:black;} .line
> {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP
> Status 404 \\u2013 Not Found</h1><hr class="line" /><p><b>Type</b> Status
> Report</p><p><b>Description</b> The origin server did not find a current
> representation for the target resource or is not willing to disclose that
> one exists.</p><hr class="line" /><h3>Apache
> Tomcat/9.0.19</h3></body></html>\'\'',))
> Kind regards
> Julierme
> On Wed, Jul 17, 2019 at 2:23 PM Ran L. <kula009 at gmail.com> wrote:
>> Hi Julierme,
>> I had the problem you described before. The reason you are getting this
>> is because the env variables are not set properly. Run this command before
>> running any other commands:
>> You should be able to run the commands then.
>> I
>> On Wed, Jul 17, 2019 at 10:19 AM 1520 gis <
>>> Hi Ran,
>>> Thank you very much for your reply. Yes, I just installed a brand new
>>> version of GeoNode-Project at 2.8 and updatelayers did not work. See the
>>> response in [1]. I then ran
>>> python manage.py makemigrations
>>> python manage.py migrate
>>> However, the problem remains. I am now asked for a superuser [2]. I did
>>> create a superuser for GeoNode-Project in a CenTOS7, but did not solve the
>>> problem. The issue also happens in GeoNode-Project at 2.10.
>>> Any help would be appreciated.
>>> Kind regards
>>> Julierme
>>> [1]
>>> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -s
>>> metoc -f previsao_meteorologica_aml
>>> File
>>> utility.execute()
>>> File
>>> File
>>> File
>>> File
>>> line 98, in handle
>>> owner = get_valid_user(user)
>>> File "/usr/src/geonode/geonode/people/utils.py", line 44, in
>>> get_valid_user
>>> theuser = get_default_user()
>>> File "/usr/src/geonode/geonode/people/utils.py", line 31, in
>>> get_default_user
>>> if superusers.count() > 0:
>>> File
>>> "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line
>>> 318, in count
>>> return self.query.get_count(using=self.db)
>>> File
>>> "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py",
>>> line 466, in get_count
>>> number = obj.get_aggregation(using, ['__count'])['__count']
>>> File
>>> line 447, in get_aggregation
>>> result = compiler.execute_sql(SINGLE)
>>> File
>>> "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py",
>>> line 840, in execute_sql
>>> cursor.execute(sql, params)
>>> File
>>> "/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line
>>> 79, in execute
>>> return super(CursorDebugWrapper, self).execute(sql, params)
>>> File
>>> 64, in execute
>>> return self.cursor.execute(sql, params)
>>> File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line
>>> 98, in __exit__
>>> six.reraise(dj_exc_type, dj_exc_value, traceback)
>>> File
>>> 64, in execute
>>> File
>>> "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py",
>>> line 318, in execute
>>> return Database.Cursor.execute(self, query, params)
>>> django.db.utils.OperationalError: no such table: people_profile
>>> [2]
>>> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -f
>>> File
>>> utility.execute()
>>> File
>>> File
>>> File
>>> File
>>> line 98, in handle
>>> get_valid_user
>>> File "/usr/src/geonode/geonode/people/utils.py", line 35, in
>>> get_default_user
>>> raise GeoNodeException('You must have an admin account configured '
>>> geonode.GeoNodeException: You must have an admin account configured
>>> before importing data. Try: django-admin.py createsuperuser
>>> On Wed, Jul 17, 2019 at 2:06 PM Ran L. <kula009 at gmail.com> wrote:
>>>> Hello Julierme,
>>>> I also had issues with the geonode "updatelayers" command yesterday,
>>>> and might have found a possible solution for it:
>>>> I'm also using geonode-project with docker on a Ubuntu machine. I
>>>> couldn't run the command successfully after building the service. You can
>>>> see the details here: https://github.com/GeoNode/geonode/issues/4650
>>>> *A fix: *I took my own customized files (templates, python files,
>>>> statics, etc.) and dump them into a newly created geonode-project. The
>>>> command worked after that.
>>>> My speculation is that the geonode-project files I had were not
>>>> compatible with the current geonode, since I haven't updated them for a
>>>> long while.
>>>> Hope this provides some insights.
>>>> Thanks!
>>>> Ran
>>>> On Wed, Jul 17, 2019 at 9:47 AM 1520 gis <
>>>>> Dear users and developers,
>>>>> I am not sure if it is on the scope of future work, but I have already
>>>>> started a tutorial to install GeoNode-Project via Docker on a CentOS7
>>>>> server. I got it installed, but not sure that I got all required geonode
>>>>> packages on a CenTOS7. Also, I had an issue while using python manage.py
>>>>> updatelayers.
>>>>> I am making myself a volunteer to help on this theme. I would like to
>>>>> share the command lines and have someones' contribution to improve what I
>>>>> got so far.
>>>>> Kind regards,
>>>>> Julierme
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190717/f7068a98/attachment-0001.html>
More information about the geonode-devel
