[GeoNode-devel] [GeoNode-users] GeoNode-Project CenTOS7 Installation
Francesco Bartoli
xbartolone at gmail.com
Wed Jul 17 11:17:52 PDT 2019
Guys, I believe you were going to use the wrong context for env variables in a container perspective, in fact the error message is referring to a local sqlite database which should not be used in the docker-compose deployment.
Defining the specific settings should do the tr
Il 17 lug 2019, 19:59 +0200, Ran L. <kula009 at gmail.com>, ha scritto:
> But you are getting a different error message this time. Could you try the simple command:
> 'django-admin updatelayers'
> And see how it goes?
> Ran
> > On Wed, Jul 17, 2019 at 10:30 AM 1520 gis <juliermeopensourcedeveloper at gmail.com> wrote:
> > > Thank you very much Ran, but the issue remains.
> > > mkdir -p /usr/src/app/; \
> > > > source $HOME/.override_env; \
> > > > echo DATABASE_URL=$DATABASE_URL; \
> > > > echo GEODATABASE_URL=$GEODATABASE_URL; \
> > > > echo SITEURL=$SITEURL; \
> > > > echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
> > > > echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION;
> > > DATABASE_URL=postgres://geonode:geonode@db:5432/geonode
> > > GEODATABASE_URL=postgis://geonode_data:geonode_data@db:5432/geonode_data
> > > SITEURL=http://cgticgeo.sipam.gov.br/
> > > ALLOWED_HOSTS=['cgticgeo.sipam.gov.br', 'cgticgeo.sipam.gov.br', 'cgticgeo.sipam.gov.br:80', 'geonode', 'django']
> > > GEOSERVER_PUBLIC_LOCATION=http://cgticgeo.sipam.gov.br/geoserver/
> > > root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -w geonode -f previsao_meteorologica_aml
> > > JSONField implementation is: <class 'jsonfield.fields.JSONField'>
> > > Inspecting the available layers in GeoServer ...
> > > Found 1 layers, starting processing
> > > Could not retrieve GeoFence Rules count.
> > > ... Creating Thumbnail for Layer [geonode:previsao_meteorologica_aml]
> > > Stopping process because --ignore-errors was not set and an error was found.
> > > Traceback (most recent call last):
> > > File "manage.py", line 31, in <module>
> > > execute_from_command_line(sys.argv)
> > > File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
> > > utility.execute()
> > > File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 346, in execute
> > > self.fetch_command(subcommand).run_from_argv(self.argv)
> > > File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 394, in run_from_argv
> > > self.execute(*args, **cmd_options)
> > > File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 445, in execute
> > > output = self.handle(*args, **options)
> > > File "/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py", line 124, in handle
> > > execute_signals=True)
> > > File "/usr/src/geonode/geonode/geoserver/helpers.py", line 630, in gs_slurp
> > > layer.set_permissions(perm_spec)
> > > File "/usr/src/geonode/geonode/security/models.py", line 205, in set_permissions
> > > sync_geofence_with_guardian(self.layer, perms, user=geofence_user)
> > > File "/usr/src/geonode/geonode/decorators.py", line 48, in wrapper
> > > return func(*args, **kwargs)
> > > File "/usr/src/geonode/geonode/security/utils.py", line 448, in sync_geofence_with_guardian
> > > _update_geofence_rule(layer.name, layer.workspace, service, user=_user)
> > > File "/usr/src/geonode/geonode/security/utils.py", line 592, in _update_geofence_rule
> > > raise RuntimeError(msg)
> > > Exception: ('Failed to process previsao_meteorologica_aml', RuntimeError('Could not ADD GeoServer User \'admin\' Rule for Layer u\'previsao_meteorologica_aml\': \'u\'<!doctype html><html lang="en"><head><title>HTTP Status 404 \\u2013 Not Found</title><style type="text/css">h1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} h2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} h3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} body {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} b {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} p {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;} a {color:black;} a.name {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 404 \\u2013 Not Found</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Description</b> The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.</p><hr class="line" /><h3>Apache Tomcat/9.0.19</h3></body></html>\'\'',))
> > > Kind regards
> > > Julierme
> > > > On Wed, Jul 17, 2019 at 2:23 PM Ran L. <kula009 at gmail.com> wrote:
> > > > > Hi Julierme,
> > > > > I had the problem you described before. The reason you are getting this is because the env variables are not set properly. Run this command before running any other commands:
> > > > > You should be able to run the commands then.
> > > > > I
> > > > > > On Wed, Jul 17, 2019 at 10:19 AM 1520 gis <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > Hi Ran,
> > > > > > > Thank you very much for your reply. Yes, I just installed a brand new version of GeoNode-Project at 2.8 and updatelayers did not work. See the response in [1]. I then ran
> > > > > > > python manage.py makemigrations
> > > > > > > python manage.py migrate
> > > > > > > However, the problem remains. I am now asked for a superuser [2]. I did create a superuser for GeoNode-Project in a CenTOS7, but did not solve the problem. The issue also happens in GeoNode-Project at 2.10.
> > > > > > > Any help would be appreciated.
> > > > > > > Kind regards
> > > > > > > Julierme
> > > > > > > [1]
> > > > > > > root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -s metoc -f previsao_meteorologica_aml
> > > > > > > utility.execute()
> > > > > > > File "/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py", line 98, in handle
> > > > > > > owner = get_valid_user(user)
> > > > > > > File "/usr/src/geonode/geonode/people/utils.py", line 44, in get_valid_user
> > > > > > > theuser = get_default_user()
> > > > > > > File "/usr/src/geonode/geonode/people/utils.py", line 31, in get_default_user
> > > > > > > if superusers.count() > 0:
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line 318, in count
> > > > > > > return self.query.get_count(using=self.db)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py", line 466, in get_count
> > > > > > > number = obj.get_aggregation(using, ['__count'])['__count']
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py", line 447, in get_aggregation
> > > > > > > result = compiler.execute_sql(SINGLE)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py", line 840, in execute_sql
> > > > > > > cursor.execute(sql, params)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line 79, in execute
> > > > > > > return super(CursorDebugWrapper, self).execute(sql, params)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line 64, in execute
> > > > > > > return self.cursor.execute(sql, params)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line 98, in __exit__
> > > > > > > six.reraise(dj_exc_type, dj_exc_value, traceback)
> > > > > > > File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py", line 318, in execute
> > > > > > > return Database.Cursor.execute(self, query, params)
> > > > > > > django.db.utils.OperationalError: no such table: people_profile
> > > > > > > [2]
> > > > > > > root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -f previsao_meteorologica_aml
> > > > > > > utility.execute()
> > > > > > > File "/usr/src/geonode/geonode/people/utils.py", line 35, in get_default_user
> > > > > > > raise GeoNodeException('You must have an admin account configured '
> > > > > > > geonode.GeoNodeException: You must have an admin account configured before importing data. Try: django-admin.py createsuperuser
> > > > > > > > On Wed, Jul 17, 2019 at 2:06 PM Ran L. <kula009 at gmail.com> wrote:
> > > > > > > > > Hello Julierme,
> > > > > > > > > I also had issues with the geonode "updatelayers" command yesterday, and might have found a possible solution for it:
> > > > > > > > > I'm also using geonode-project with docker on a Ubuntu machine. I couldn't run the command successfully after building the service. You can see the details here: https://github.com/GeoNode/geonode/issues/4650
> > > > > > > > > A fix: I took my own customized files (templates, python files, statics, etc.) and dump them into a newly created geonode-project. The command worked after that.
> > > > > > > > > My speculation is that the geonode-project files I had were not compatible with the current geonode, since I haven't updated them for a long while.
> > > > > > > > > Hope this provides some insights.
> > > > > > > > > Thanks!
> > > > > > > > > Ran
> > > > > > > > > > On Wed, Jul 17, 2019 at 9:47 AM 1520 gis <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > > > > > Dear users and developers,
> > > > > > > > > > > I am not sure if it is on the scope of future work, but I have already started a tutorial to install GeoNode-Project via Docker on a CentOS7 server. I got it installed, but not sure that I got all required geonode packages on a CenTOS7. Also, I had an issue while using python manage.py updatelayers.
> > > > > > > > > > > I am making myself a volunteer to help on this theme. I would like to share the command lines and have someones' contribution to improve what I got so far.
> > > > > > > > > > > Kind regards,
> > > > > > > > > > > Julierme
> > > > > > > > > > > _______________________________________________
> > > > > > > > > > > geonode-users mailing list
> > > > > > > > > > > geonode-users at lists.osgeo.org
> > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190717/b74f3dbd/attachment-0001.html>
More information about the geonode-devel
