[GeoNode-devel] PSC: Continue with Transifex yes/no
Simone Dalmasso
simone.dalmasso at gmail.com
Wed May 1 00:52:39 PDT 2019
+1 for me as well and second Francesco's suggestion.
Ciao!
Il giorno mer 1 mag 2019 alle ore 09:23 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> +1. However I would try to advise users who have recently updated the
> translation on Transiflex to encouraging them to port it over github.
> Il 30 apr 2019, 17:49 +0200, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> +1 to shutdown Transifex, using PRs, as usual, is much more trackable,
> revertable and reliable.
> Il giorno mar 30 apr 2019 alle ore 13:52 Florian Hoedt <
> florian.hoedt at thuenen.de> ha scritto:
>> Hi,
>> My +1 for Shutdown Transifex and stay with PR´s as explained here [2]?
>> I think the google doc is very easy to follow and we do not need
>> Transifex as collaborative plattform.
>> cheers,
>> Florian
>> [2]
>> https://docs.google.com/document/d/1DKSznzz6m8PWDGNgFwdxN1jOd0s4tH8y036K96CBfYs/edit#heading=h.305bg1fpxz2o
>> MSc Florian Hoedt
>> Koordinator Geoinformation | Coordinator Geoinformatics
>> Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute,
>> Centre for Information Management
>> Bundesallee 44
>> 38116 Braunschweig
>> Tel: +49 531 596-1428
>> Fax: +49 531 596-1499
>> Mail: florian.hoedt at thuenen.de
>> Web: www.thuenen.de
>> Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für
>> Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus
>> 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie
>> forschen und die Politik beraten.
>> The Johann Heinrich von Thünen Institute, Federal Research Institute for
>> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
>> of 14 specialized institutes that carry out research and provide policy
>> advice in the fields of economy, ecology and technology.
>> *Von:* "Toni Schönbuchner" <toni.schoenbuchner at csgis.de>
>> *An:* "geonode-devel" <geonode-devel at lists.osgeo.org>
>> *Gesendet:* Dienstag, 30. April 2019 09:50:44
>> *Betreff:* [GeoNode-devel] PSC: Continue with Transifex yes/no
>> Dear PSC members,
>> Dear Devs,
>> with the lastest update [1] of translations a discussion at Gitter
>> started whether the use of Transifex still makes sense.
>> The current situation is that Transifex has little or no maintenance.
>> Furthermore, many translations are out of sync with Github.
>> It may well happen that somebody invests time working on an outdated
>> translation at Transifex but overwrites a newer po file at GitHub.
>> At Gitter, we agreed that translations will be easier to maintain by just
>> editing a language file locally and then creating a PR.
>> The question is therefore:
>> Your +1 / -1 or any further idea is very welcome.
>> (Angelos Tzotsos and Alessio Fabiani already gave their +1 at Gitter)
>> Best regards,
>> Toni
>> [1] https://github.com/GeoNode/geonode/pull/4372
>> [2]
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Tel +49/ (0) 341 24 04 738
>> Fax +49/ (0) 341 24 04 739
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> geonode-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190501/c7121b29/attachment.html>
More information about the geonode-devel
