[GeoNode-devel] [GeoNode-users] A call for help!
Amedeo Fadini amefad at gmail.com
Wed Oct 23 14:54:59 PDT 2019
Hi Toni,
I'm here to help...
should I use a spatialite database or postgis or both? Is there any default
dataset available or can I use any kind of data?
Amedeo
Il giorno mer 23 ott 2019 alle ore 18:33 Toni Schönbuchner <
toni.schoenbuchner at csgis.de> ha scritto:
> Dear community,
> this is a call to help with the next GeoNode release 2.10.1. While last
> bugs get ironed out. We need every helping hand with testing.
> ( The more we test the fewer regressions, the easier our life will be ;)
> Alessio kindly provided us the following test sheet:
> https://docs.google.com/spreadsheets/d/13aaZ1l_2_SHzdmz9DwExEO_jxwgNuXfMa6oF5eWIv_s/edit#gid=376642658
> For help with testing, you should have a basic understanding of the
> capabilities and components of GeoNode. As test-environment, GeoNode can be
> started in DEBUG mode:
> http://docs.geonode.org/en/2.10.x/install/core/index.html#geonode-installation
> Please use the 2.10.1 branch!
> $ git clone https://github.com/GeoNode/geonode.git -b 2.10.1
> Once a test is completed, please do not forget to change the status and
> result of your test. In case of an error please leave a comment with your
> name in the box provided.
> While you're working on it please set the status to "in progress".
> A big thank you in advance!
> Toni
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191023/7bc6cf73/attachment.html>
More information about the geonode-devel mailing list
