[GeoNode-devel] [GeoNode-users] A call for help!
    Amedeo Fadini
    amefad at gmail.com
    Wed Oct 23 14:57:42 PDT 2019
It seems that column "description" in the test sheed has been replaced by a
bit of SLD style fragments...  from line 32 ongoing.
Amedeo
Il giorno mer 23 ott 2019 alle ore 23:54 Amedeo Fadini <amefad at gmail.com>
ha scritto:
> Hi Toni,
> I'm here to help...
> should I use a spatialite database or postgis or both? Is there any
> default dataset available or can I use any kind of data?
> Amedeo
> Il giorno mer 23 ott 2019 alle ore 18:33 Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> ha scritto:
>> Dear community,
>> this is a call to help with the next GeoNode release 2.10.1. While last
>> bugs get ironed out. We need every helping hand with testing.
>> ( The more we test the fewer regressions, the easier our life will be ;)
>> Alessio kindly provided us the following test sheet:
>> https://docs.google.com/spreadsheets/d/13aaZ1l_2_SHzdmz9DwExEO_jxwgNuXfMa6oF5eWIv_s/edit#gid=376642658
>> For help with testing, you should have a basic understanding of the
>> capabilities and components of GeoNode. As test-environment, GeoNode can be
>> started in DEBUG mode:
>> http://docs.geonode.org/en/2.10.x/install/core/index.html#geonode-installation
>> Please use the 2.10.1 branch!
>> $ git clone https://github.com/GeoNode/geonode.git -b 2.10.1
>> Once a test is completed, please do not forget to change the status and
>> result of your test. In case of an error please leave a comment with your
>> name in the box provided.
>> While you're working on it please set the status to "in progress".
>> A big thank you in advance!
>> Toni
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191023/c37912e8/attachment.html>
More information about the geonode-devel
