[GeoNode-devel] GeoNode/GeoServer track user disk usage
Pattara Kiatisevi
pattara at longdo.com
Mon May 9 09:13:40 PDT 2022
Dear Giovanni,
Thank you very much for your reply. Our team will have a look into it.
Cheers,
Pattara
On Fri, May 6, 2022 at 7:29 PM Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> wrote:
> Dear Pattara,
> currently, there's no direct mechanism to calculate the storage space
> taken by files uploaded by single users. The Upload model provides a
> linkage between a user and the uploaded files, so one could calculate the
> total size of uploaded files by a user. however:
> - GeoNode doesn't strictly require the uploaded files to be kept (as
> original data copies) inside its storage space. At this moment it's
> automatically requested when the upload is performed from the Web UI, but
> the upload API provides a flag to request either to keep the uploaded files
> or not. This is not a big concern if uploads are performed only through the
> Web UI
> - GeoNode transfers the uploaded data to Geoserver which, in its turn,
> will store it inside its own storage systems (DB for vector data,
> filesystem for raster data). This storage space should be taken into
> account to have the real total space taken by a user.
> - For documents, things are much simpler since they're only stored and
> served by GeoNode
> By the way, one can assume that files are only uploaded only from the UI
> and stored both as a raw copy in GeoNode and as published data in
> Geoserver. From the Upload model, the first can be calculated and the
> latter can be estimated.
> Things will probably change in the future, since there are plans to
> improve this flow, avoiding storage duplication as much as possible.
> Regards,
> Giovanni
> On Thu, May 5, 2022 at 12:03 PM Pattara Kiatisevi <pattara at longdo.com>
> wrote:
>> Dear GeoNode-devel,
>> Is there an easy way to track storage space used by users in GeoNode?
>> We are thinking of adding a check when uploading and delete layers but
>> just in case there is a better way.
>> Thank you very much,
>> Pattara
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 345 2815774
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220509/dd3a4320/attachment.htm>
More information about the geonode-devel
