[GeoNode-devel] [GeoNode-users] Geonode Harvesters
    Alessio Fabiani
    alessio.fabiani at geosolutionsgroup.com
    Mon Sep 25 00:28:15 PDT 2023
Are you running GeoNode in ASYNC mode?
On Sun, Sep 24, 2023 at 6:45 PM Kabatha Patrick via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi there,
> Anyone who has successfully set-up a geonode harvester. Everything seems
> fine here:
> [image: image.png]
> But I don't get the list of harvestable resources as explained in this
> tutorial
> <https://training.geonode.geosolutionsgroup.com/master/GN2/HARVESTERS/index.html>.
> Is there configurations that need to be done on the remote server (i.e.
> where resources are being harvested from).
> Anyone who has successfully set up the harvesting session?
> Thanks,
> GIS Analyst
> Geography & Ecology.
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230925/be38280c/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230925/be38280c/attachment-0001.png>
More information about the geonode-devel
