[GeoNode-devel] [GeoNode-users] Geonode Harvesters
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Tue Sep 26 01:18:48 PDT 2023
I've done a test with the development demo, harvesting the stable demo, and
it looks almost good.
   1. Created the harvester (with scheduling disabled)
   2. Selected the harvester and executed the action "Perform harvesting on
   selected harvesters"
   3. An Async session has started with type
   "disocer-harvestable-resources".
The problem is that it looks stalled after a while. The ingested
resources do not increase and the session is still marked "ongoing". See
image below.
We will have to investigate...
[image: image.png]
Giovanni
On Mon, Sep 25, 2023 at 8:38 PM Kabatha Patrick via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi Alessio,
> No. I don't think so.
> I simply installed geonode using the basic installation procedure
> <https://training.geonode.geosolutionsgroup.com/master/GN3/basic_install/index.html>.
> Configured the .env_local files and nginx appropriately and now running in
> production mode.
> On Mon, Sep 25, 2023 at 10:28 AM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> Are you running GeoNode in ASYNC mode?
>> On Sun, Sep 24, 2023 at 6:45 PM Kabatha Patrick via geonode-users <
>>> Hi there,
>>> Anyone who has successfully set-up a geonode harvester. Everything seems
>>> fine here:
>>> [image: image.png]
>>> But I don't get the list of harvestable resources as explained in this
>>> tutorial
>>> <https://training.geonode.geosolutionsgroup.com/master/GN2/HARVESTERS/index.html>.
>>> Is there configurations that need to be done on the remote server (i.e.
>>> where resources are being harvested from).
>>> Anyone who has successfully set up the harvesting session?
>>> Thanks,
>>> GIS Analyst
>>> Geography & Ecology.
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  331 6233686
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> GIS Analyst
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
cell:     +39 345 2815774
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230926/7bc55b31/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230926/7bc55b31/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230926/7bc55b31/attachment-0003.png>
More information about the geonode-devel mailing list
