[GeoNode-users] getfeature info display option
Eugenio Trumpy
frippe12573 at hotmail.com
Tue Apr 18 06:46:45 PDT 2017
I have worked on this issues, and I discovered something new.
The 'info format' combo box appears only on 'layer properties' when you load the layer by using the button 'add layer' (the plus icon) from the map composer and nit doesn't appear if you choose 'create a map' from the layer info page. After that if you save the map with the chosen format for a layer, you can have such format also by getfeature info from the map info page.
Is it possible according to the developed code?
I think having the possibility to choose the info format also before to create a map it would be really useful.
Do you think it could be possible?
Cheers
Eugenio
Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Inviato: giovedì 6 aprile 2017 12.22
A: Eugenio Trumpy
Cc: Alessio Fabiani; geonode-users at lists.osgeo.org
Oggetto: Re: [GeoNode-users] getfeature info display option
Can you maybe try some sort of configuration here geonode/templates/geonode/geo_header.html ?
I'm not quite sure GeoExplorer plugins will allow you to set this property by default. You may need some customization from django-geoexplorer project or either change gis client on geonode.
If you are using latest geonode versions, the new REACT client is quite cool.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github<https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it<http://www.geo-solutions.it/>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Apr 6, 2017 at 11:54 AM, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> wrote:
I deepen that problem. For layers uploaded in the geonode geoserver in the map from layer properties - display I have info format combo box to choose the format (see attached picture_1).
In this case, is there the possibility to set up the default format? if yes where it can be set?
For layers from external webservices (e.g. WMS o WFS from another geoserver) the info format combo box doesn't appear (see attached picture_2).
Is that normal? If yes, how can I set the info format as text/html?
This is very important to me since I have set many links to be used by the users in the datasets I provide via geonode.
E.
Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
Inviato: giovedì 6 aprile 2017 11.11
A: Eugenio Trumpy
Cc: Alessio Fabiani; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Then, in the latest GeoNode versions it is already configured to use HTML as outputformat (as far as I can see).
[Inline image 1]
Best Regards,
Alessio Fabiani.
GeoSolutions Enterprise Services<http://goo.gl/it488V>
goo.gl<http://goo.gl>
GeoSolutions offers enterprise support services to help you building enterprise-class Spatial Data Infrastructures leveraging on best-of-breed Open Source
@alfa7691
GeoSolutions S.A.S.
Italy
phone: +39 0584 962313<tel:0584%20962313>
fax: +39 0584 1660272<tel:0584%20166%200272>
mob: +39 331 6233686<tel:331%20623%203686>
On Thu, Apr 6, 2017 at 11:07 AM, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> wrote:
yes I am.
Inviato: giovedì 6 aprile 2017 10.59
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
GeoServer for sure allows it. If not possible on the client it depends either from the client configuration or widgets.
Are you using the default geoexplorer client on GeoNode?
Best Regards,
Alessio Fabiani.
@alfa7691
GeoSolutions S.A.S.
Italy
On Wed, Apr 5, 2017 at 6:20 PM, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> wrote:
I remember there was the possibility to choose (or setup) the format of how to display the featureinfo box.
That's way I need to show it as HTML in order to let users to use a link I put in a filed.
Am I wrong?
If not how can I allow it?
E.
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170418/17ffa1b6/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170418/17ffa1b6/attachment-0001.png>
More information about the geonode-users
