[GeoNode-users] mod_wsgi.so issue
Jeremiah Zellers jeremiah.zellers.wf0d at statefarm.com
Mon Jun 5 09:13:36 PDT 2017
Hello,
I have used the Windows binary installer to install GeoNode 2.6.x onto a Windows 7 machine.  When I use winLamp to start apache, I get an error:
Syntax error line 241
mod_wsgi.so could not load into server
I have verified that the module is present in the modules folder. I have verified that the Syntax on line 241 is correct. It's identical to the other modules that load properly. I have verified that all permission are correct for mod_wsgi.so. I'm new to all of this, so any help you can offer would be excellent. Is there anything else I can check?
Thank you,
Jeremiah
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170605/c0b1de49/attachment.html>
More information about the geonode-users mailing list
