[GeoNode-users] mod_wsgi.so issue
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jun 7 07:39:32 PDT 2017
Can you please double check that GDAL also has been installed and it is
working correctly on your system?
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Jun 5, 2017 at 6:13 PM, Jeremiah Zellers <
jeremiah.zellers.wf0d at statefarm.com> wrote:
> Hello,
> I have used the Windows binary installer to install GeoNode 2.6.x onto a
> Windows 7 machine.  When I use winLamp to start apache, I get an error:
> Syntax error line 241
> mod_wsgi.so could not load into server
> I have verified that the module is present in the modules folder. I have
> verified that the Syntax on line 241 is correct. It’s identical to the
> other modules that load properly. I have verified that all permission are
> correct for mod_wsgi.so. I’m new to all of this, so any help you can offer
> would be excellent. Is there anything else I can check?
> Thank you,
> Jeremiah
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170607/47e9f883/attachment-0001.html>
More information about the geonode-users mailing list
