[GeoNode-users] publishing layer from an ImageMosaic store fails with BandSelect error
Simone Dalmasso simone.dalmasso at gmail.com
Mon Oct 2 07:31:28 PDT 2017
Thanks for sharing it Simone!
ciao
2017-10-02 16:11 GMT+02:00 simone balbo <simone.blb at gmail.com>:
> Hi all,
> I've found (probably) a workaround for the situation in subject.
> Basically I switched back to a previous version of GeoTools for the
> ImageMosaic jar.
> In particular I did:
>    - download the "geotools-14.5-bin.zip" folder from the SourceForce
>    site (https://sourceforge.net/projects/geotools/files/
>    GeoTools%2014%20Releases/14.5/)
>    - unzip the folder
>    - locate the image mosaic jar file, which is: gt-imagemosaic-14.5.jar
>    - substitute the current image mosaic jar file (...15-SNAPSHOT) in the
>    GeoServer lib folder (/usr/share/geoserver/WEB-INF/lib) with the one
>    at the previous point (basically by renaming them appropriately)
>    - restart tomcat
> With the described workaround I can successfully generate and browse an
> image mosaic layer.
> Anyhow I'm aware that better solutions may be available. Is it better to
> upgrade the entire GeoServer application to 2.10.x? In such case is there a
> detailed documentation on how to do so step by step (e.g. on migrating the
> data directory and authentication)?
> Cheers,
> Simone
> On 29 September 2017 at 10:41, Paolo Pasquali <
> paolo.pasquali at ithaca.polito.it> wrote:
>> Hi all,
>> I have a GeoNode 2.6.3 installed on my Mac (so custom installation) with
>> Oracle Java 1.8.0_121
>> I successfully created a mosaic with a small set of Tiff.
>> The problem occurs in GeoNode 2.6.3 apt packaged installed on Ubuntu 16
>> and Oracle Java 1.8.0_144
>> Using the same set of rasters the mosaic can't be published and I get:
>> java.lang.IllegalArgumentException: The number of image bands (3)
>> differs from the number of supplied 'SampleDimension' objects (0)
>> The first two rasters can be singly published but if I try to publish a
>> mosaic made of these two rasters I get:
>> java.lang.IllegalArgumentException: BandSelect operation requires the
>> band indices to have at least 1 array element.
>> Same error as Simone's.
>> Any help would be much appreciated.
>> Thanks.
>> Paolo
>> On Tue, Sep 26, 2017 at 12:42 PM, simone balbo <simone.blb at gmail.com>
>> wrote:
>>> Hi everybody,
>>> I'm experiencing this behavior in the following conditions:
>>>    - GeoNode 2.6.3, installed with the apt package manager (GeoServer
>>>    2.9-SNAPSHOT)
>>>    - an ImageMosaic store is created successfully with default
>>>    parameters in GeoServer
>>>    - the image mosaic is composed by 3-bands 8-bit images
>>>    - when trying to publish the layer from this store (by clicking the
>>>    "Publish" button from GeoServer) I get the error "BandSelect operation
>>>    requires the band indices to have at least 1 array element" (complete error
>>>    stack is attached)
>>> The strange thing is that I can successfully publish the same mosaic
>>> layer with an earlier GeoServer version (2.8.2).
>>> Am I missing something? Some library?
>>> Does anybody have the same issue?
>>> Cheers,
>>> Simone
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171002/b90f6a76/attachment.html>
More information about the geonode-users mailing list
