[GeoNode-users] SRC not established from *.prj. Non admin Users can´t select SRC of layers they upload.
Stefan Steiniger
sstein at geo.uzh.ch
Tue Oct 3 06:33:19 PDT 2017
I don't have a problem with uploading data in UTM19S in V2.0, so I guess it's either a degression (not likely) or an issue with your *.prj file/definition strings. My shapefile are mostly from QGIS, though.
Cheers,
Stefan
> El 03-10-2017, a las 10:24, Ariel Neri <ariel.neriw at gmail.com> escribió:
> Hi, i´m using Geonode 2.6. Neather I, nor the users of our geonode portal could find the way to establish the correct SRC on their layers (I thought they could from the metadata edition section but i was wrong), apart from the admin interface or Geoserver UI.
> When a new shapefile is uploaded, a default SRC is set (40400), no matter what the *.prj inidcates. Only EPSG:4326 shapefiles are set correctly (most of our work is on UTM). Is this a miss-configuration on our GeoNode or that´s the way it works?
> If it´s a local problem, would you indicate what files should i search for the problem?
> At the moment i´m correcting that from Geoserver UI, but it would be very usefull if non-admin users could do it themselves on their layers.
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
