[GeoNode-users] Problem with legend in Geoexplorer
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Dec 13 03:03:43 PST 2018
Hello Jose,
try to change the legend icon on GeoServer SLD directly. It should also
possible, by using the versions 2.13 and above, to set a custom png as
LegendIcon.
You might be able to find more details on the official GeoServer Docs.
Il giorno mer 12 dic 2018 alle ore 15:32 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi everyone,
> I'm running Geonode 2.8 on this site: http://206.189.229.38/, is supposed
> to be open so no worries sharing that, besides any feedback will be
> appreciated as I'm not and expert on development.
> Anyway my specific problem this time is on how the style of the layers are
> display in Geoexplorer, they're showing pretty big on the layers panel in
> Geoexplorer as shown in the attachment. I've change some thing in the
> base.css file and index.html file but I don't think I've change anything
> related to that. I've load the same layers on the Geonode Demo, as seen in
> the attachment, and it does shows a normal size as it was showing before on
> my site, and I can't find in the debug console where is the style coming
> from.
> Please any help or guidance will be much appreciated.
> Kind Regards,
> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 12/12/18
> 08:23:12
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181213/46cfaff8/attachment-0001.html>
More information about the geonode-users mailing list
