[GeoNode-users] User Account Registration (Julierme Pinheiro)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Fri Jul 13 09:26:09 PDT 2018
Dear Toni,
I have good news. The issues are over!!!! :-)
I went home thinking about what you said: "I would strongly recommend that
you remove the development environment machine to
avoid further confusion". Before dumping GeoNode Development (GD), I
changed geonode.conf in one way that GeoNode Production (GP) will get blind
to GD.
I, then, realized that the same issue was happening while working  only
with GP. And I started tweaking through the settings.py and the
local_settings.py  and I solved the issues in two steps:
Step 1) in my case, SITEURL must be declared in my settings.py
Note: 1.1 I was declaring it in local_settings.py only (Not enough)
         1.2 If I change my_geonode/wsgi.py to point to local_settings.py
instead of settings.py, Apache2 won't start.
Step2) I did just the same. Instead of declaring the code bellow in
local_settings.py, I did in the settings.py
REGISTRATION_OPEN = True
EMAIL_ENABLE = True
if EMAIL_ENABLE:
   EMAIL_BACKEND = 'django.core.mail.backends.smtp.EmailBackend'
   EMAIL_HOST = 'smtp.sipam.gov.br'
   EMAIL_PORT = 587
   EMAIL_HOST_USER ='uap.ccg.geonode'
   EMAIL_HOST_PASSWORD = 'passwd'
   EMAIL_USE_TLS = True
   DEFAULT_FROM_EMAIL = 'uap.ccg.geonode at sipam.gov.br‘
THEME_ACCOUNT_CONTACT_EMAIL = DEFAULT_FROM_EMAIL
Note: 2.1 I was declaring it in local_settings.py only (Not enough)
         2.2 If I change my_geonode/wsgi.py to point to local_settings.py
That was it. Thumbnails are working like a charm and I am sending e-mails.
Thank you very much for your time and help.
I appreciated it.
Kind regards,
Julierme
On Wed, Jul 11, 2018 at 7:25 AM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Julierme,
> thanks for providing me your VM. I´ve examined it more closely
> and will set geonode-users as CC.
> I am facing a problem with thumbnails url related to port 8000. As you can
> see through the /home/geonode/my_geonode/my_geonode/local_settings.py,
> the
> It seems like you caused a bit confusion with your mix of dev and
> production setups.
> DEVELOPMENT – This is what I did:
> $ sudo service tomcat8 stop
> $ sudo service postgresql stop
> $ sudo service apache2 stop
> This was needed as I´ve recognized that tomcat8 ist already running on
> port 8080!
> – but we´d like to use jetty in dev mode
> # Activate the virtualenv
> $ source /home/geo/Envs/my_geonode/bin/activate
> # change to the project root and run paver tasks
> $ cd /home/my_geonode/my_geonode
> $ paver setup && paver sync && paver start
> The dev server started and I could upload a demo shape file with working
> thumbnail
> as proven by this snapshot :https://www.dropbox.com/s/
> bedw4oxgf2j67ck/dev.png?dl=0
> PRODUCTION:
> # Stop dev server,  deactivate dev-virtualenv,  activate prod-virtualenv,
> change to production dir
> $ paver stop
> $ deactivate
> $ source /home/geo/Envs/geonode/bin/activate
> $ cd /home/geonode/my_geonode
> NOW! have a look at my_geonode/wsgi.py it´s pointing to settings.py but we
> want to use local_settings which
> then includes settings.py. Within the file change DJANGO_SETTINGS_MODULE
> to my_geonode.local_settings
> save and close
> # remove unneeded vhost, start production server, sync database
> $ sudo a2dissite 000-default.conf
> $ sudo service tomcat8 start
> $ sudo service postgresql start
> $ sudo service apache2 start
> # wait a bit – tomcat needs some time to start deploy and geoserver
> $ paver sync
> After that we can see that a test upload works with thumbnail in
> „production“
> geoserver is running and used for the layer upload:
> https://www.dropbox.com/s/v254zzg8jpq5fxg/prod.png?dl=0
> https://www.dropbox.com/s/y0sfmke8naia9pv/prod2.png?dl=0
> https://www.dropbox.com/s/1io3z7xeokun5xy/geoserver.png?dl=0
> Note: When uploading the layer the target dir for uploaded files was
> pointing to your dev environment
> I couldn´t figured out why but just allowed the user to write to the dir I
> leave this problem for you
> EMAIL:
> I am sorry to insist on this topic, I wonder if another GeoNode at 2.8.0
> user has faced the same problem while configuring users email account. I am
> using GeoNode Production (/home/geonode/...) and GeoNode DevMode
> I´ve tested your postfix with telnet. Looks all good. I would ask you to
> try the following.
> In production environment edit your E-mail settings in local_settings.py
> like
> EMAIL_ENABLE = True
> if EMAIL_ENABLE:
>    EMAIL_PORT = 587
> Please double check that you provide correct credentials.
> Then It should work that you send a testmail by use of django shell:
> https://docs.djangoproject.com/en/2.0/topics/email/#quick-example
> Further if no mails arrive at all visit your mail server admin and make
> sure the listening
> server accepts your sending (spam settings).
> So far, sorry for the lengthy email.
> All the best to Brasilia,
> Toni
> CSGIS
> Kolonnadenstraße 1
> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180713/a2bf2596/attachment-0001.html>
More information about the geonode-users mailing list
