[GeoNode-users] GeoNode Docker Installation
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Jul 25 07:48:33 PDT 2018
Dear Toni,
Thank you very much for the advises, information and  video 21':26" long. I
appreciated your work, help and time.
I made it.
I followed your entire video to install GeoNode in a CentOS7 VM.
The only thing I had to do was to install docker and docker-compose for a
CentOS7. From cloning the repository (git clone
https://github.com/GeoNode/geonode.git) on, all works the same as Ubuntu,
If I am not mistaking something. GeoNode is up and running smoothly.
I did not find a GeoNode Docker installation tutorial for CentOS, if you
want, I can share the steps I had to go through to get it installed.
Thank you very much for the video.
Kind regards
Julierme
On Tue, Jul 24, 2018 at 4:13 AM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Julierme,
> the rclone setup is specific to SPCGeoNode. Unfortunately I cannot explain
> what´s going
> wrong here.
> My advise would be to file an issue for Oliver at SPC Geonode repository:
> https://github.com/olivierdalang/SPCgeonode/issues
> To make sure all Information is there to solve your problem you can have a
> look at this Issue template:
> https://gist.github.com/t-book/5dda86218b0bc6e8f958339f1bf67f68
> In between I would suggest to try the official GeoNode Docker Stack.
> Therefore I´ve recorded
> a little Video for you which guides you through the steps:
> https://vimeo.com/281179387?utm_source=email&utm_medium=
> vimeo-cliptranscode-201504&utm_campaign=29220
> As this is with Ubuntu and installing docker might work a bit different
> under centos you can directly jump
> to Minute 2:10. There you see the the hello-world test which makes sure
> docker is up and running
> correctly.
> Let me know if you have problems.
> Best,
> Toni
> CSGIS
> Kolonnadenstraße 1
> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 24.07.2018 um 00:16 schrieb Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com>:
> Hi Toni,
> It is not something very fancy and I am not sure if I can do that without
> causing another problem, but I did the following in order to have the
> command (
> docker-compose -f docker-compose.yml up -d --build) running from its begin to the end.
> 1 - I downloaded the file via wget
>  <https://downloads.rclone.org/v1.39/rclone-v1.39-linux-amd64.zip>2 - I unzipped the file  rclone-v1.39-linux-amd64.zip
> 3 - I removed the file rclone-v1.39-linux-amd64.zip
> 4 - I moved the file rclone-v1.39-linux-amd64.zip to /usr/bin
> 5 - I commented the following line in the Dockerfile
> # 3. Install Rclone
> #RUN wget https://downloads.rclone.org/v1.39/rclone-v1.39-linux-amd64.zip
> #RUN unzip /rclone-v1.39-linux-amd64.zip
> #RUN rm /rclone-v1.39-linux-amd64.zip
> #RUN mv /rclone-v1.39-linux-amd64/rclone /usr/bin
> I appreciated you time
> Kind regards
> Julierme
> On Mon, Jul 23, 2018 at 4:51 PM, Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Thank you very much for your reply Toni. Yes, the wget you sent in the
>> previous e-mail works. I realized that if I run this command /bin/sh -c
>> "wget https://downloads.rclone.org/v1.39/rclone-v1.39-linux-amd64.zip"
>> with wget between double quotes works too. I tried setting the wget between
>> quotes (RUN "wget https://downloads.rclone.org/v
>> 1.39/rclone-v1.39-linux-amd64.zip") in ./SPCgeonode/_service_rclone/Dockerfile
>> and got the following error:
>> Step 3/17 : RUN 'wget https://downloads.rclone.org/v
>> 1.39/rclone-v1.39-linux-amd64.zip'
>>  ---> Running in 2d761040c8cf
>> /bin/sh: wget https://downloads.rclone.org/v
>> 1.39/rclone-v1.39-linux-amd64.zip: not found
>> ERROR: Service 'rclone' failed to build: The command '/bin/sh -c 'wget
>> https://downloads.rclone.org/v1.39/rclone-v1.39-linux-amd64.zip''
>> returned a non-zero code: 127
>> I am still tweaking through the Dockerfile in order to build something
>> similar to /bin/sh -c "wget https://downloads.rclone.org/v
>> I appreciated your help.
>> Kind regards
>> Julierme
>> On Mon, Jul 23, 2018 at 3:46 PM, Toni Schönbuchner <
>>> Hi Julierme,
>>>  does it work when you spoof a Major Browser?
>>> wget "https://downloads.rclone.org/v1.39/rclone-v1.39-linux-amd64.zip" --user-agent="Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.6) Gecko/20070725 Firefox/2.0.0.6"
>>> Cheers toni
>>> Am 23.07.2018 um 19:06 schrieb Julierme Pinheiro <
>>> Dear GeoNode users,
>>> I got all the prerequisites stated by @olivierdalang
>>> <https://github.com/olivierdalang/SPCgeonode> installed in CentOS VM.
>>> During step 3/17:  "RUN wget https://downloads.rclone.org/v
>>> 1.39/rclone-v1.39-linux-amd64.zip", related to the container ID
>>> "dbf265cb3519", I got an error message bellow and I wonder if this error is
>>> related to firewall. My first guess is not, because the download windows is
>>> shown while accessing the link https://downloads.rclone.org/v
>>> 1.39/rclone-v1.39-linux-amd64.zip in the browser.
>>> Any hint on that will be very appreciated?
>>> Thank you for your time and help in advance.
>>> Kind regards
>>> Julierme
>>> Error Message:
>>> Connecting to downloads.rclone.org (5.153.250.7:443)
>>> ssl_client: downloads.rclone.org: TLS connect failed
>>> wget: error getting response: Connection reset by peer
>>> ERROR: Service 'rclone' failed to build: The command '/bin/sh -c wget
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180725/c6801d27/attachment.html>
More information about the geonode-users mailing list
