[GeoNode-users] how to make multiple overlay name (Handy Rusydi)
Paolo Corti
pcorti at gmail.com
Mon Nov 26 08:53:35 PST 2018
Hi Handy
the process is more or less the following - which is not trivial:
* fork this repository https://github.com/GeoNode/geoexplorer
* change it accordingly to your needs
* while changing the code to your needs, you can debug your code by
changing this line
https://github.com/GeoNode/geonode/blob/master/geonode/client/templates/geoext/maps/map_geoexplorer.js#L3
to include geoext/geo_header_debug.html vs geoext/geo_header.html Then
you can run "ant debug" and use the browser debugger to observe the
code beahviour
* once done build your client running "ant buildjs"
* replace the static files from the standard GeoNode client with your
forked version. Best way to do it would be to package your static
files in pypi by using a forked version of this repository:
https://github.com/GeoNode/django-geoexplorer
best regards
Paolo
On Fri, Nov 23, 2018 at 4:13 AM Handy Rusydi <handy at galerigis.com> wrote:
> I have read how to debug or make redevelopment of layer preview. We should have to debug or uncompressed javascript library like geoext ( in this case the name is geoexplorer). I dont know how, after that we should have to compress again in geonode (correct if I am wrong).
> I have decide that to used only categorize in worldmap and any other still default way. It means that I should to edit the geoxt for my self.
> Thanks anyway
> Regards
> Handy
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
