[GeoNode-users] Uploading Shapefile(Polygon features) - Displaying as Point in GeoNode Map/layer View
Naresh N naresh919 at gmail.com
Tue Apr 9 03:34:21 PDT 2019
Hello All,
Thanks for responding. Please find the attached Shapefile of polygon. After
Uploading any shapfiile of type polygon/line, in GeoNode Map/Layer viewer,
only point is visible. I have verified the code/db, the issue is point SLD
is applied for uploaded data independent of feature type . And also in
Layer/Map Viewer ---> EDIT --> *CREATE option* is *disabled.*
Please kindly help us in GeoNode which part of code/file verifies
feature/Geometry type(Polygon/lIne/point) of Shapefile and assigns
corresponding default SLD
Kindly help us to resolve the issues
Thanks&Regards,
Naresh.N
On Tue, Apr 9, 2019 at 2:58 AM juliermeopensourcedeveloper [via OSGeo.org] <
ml+s1560n5401239h2 at n6.nabble.com> wrote:
> Hi Naresh,
> Could you provide the shapefile you are having problem?
> Kind regards
> Julierme
> On Mon, 8 Apr 2019 at 08:28 Naresh N <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5401239&i=0>> wrote:
>> Dear All,
>> I have deployed the GeoNode 2.4 version by following  the instructions
>> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/setup_on_centos/index.html
>> *ISSUE : *When I am uploading shapefile(polygon), it is taking the
>> default point SLD. Hence when I am viewing the Uploaded Shapfeil(polygon)
>> as WMS in Map/Layer View , it is displaying as point.
>> *Kindly help me to resolve this issue. *
>> GeoNode Deployed system configuration are
>> *OS:*RHEL 7.2, 64 bit , GeoNode2.4 version
>> Please let me know any other information required further to understand
>> the issue.
>> Thanks&Regards,
>> Naresh.N
>> geonode-users mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=1>
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-devel mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=2>
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-Uploading-Shapefile-Polygon-features-Displaying-as-Point-in-GeoNode-Map-layer-View-tp5401239.html
> To unsubscribe from GeoNode, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185390&code=bmFyZXNoOTE5QGdtYWlsLmNvbXw1MTg1MzkwfC0xMDc3NTYzNDE5>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190409/3e881df5/attachment.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190409/3e881df5/attachment.bin>
More information about the geonode-users mailing list
