[GeoNode-users] Uploading Shapefile(Polygon features) - Displaying as Point in GeoNode Map/layer View
1520 gis
juliermeopensourcedeveloper at gmail.com
Tue Apr 9 10:39:09 PDT 2019
Hi Naresh,
Thank you for providing the shapefile. Your shapefile is actually a polygon
feature type. Open it in QGis and you will see that. What is making you a
little bit confuse is the feature scale. For small scale, your polygon
looks like a point feature, but it is actually a polygon.
I hope it helps
Julierme
On Tue, Apr 9, 2019 at 7:34 AM Naresh N <naresh919 at gmail.com> wrote:
> Hello All,
> Thanks for responding. Please find the attached Shapefile of polygon.
> After Uploading any shapfiile of type polygon/line, in GeoNode Map/Layer
> viewer, only point is visible. I have verified the code/db, the issue is
> point SLD is applied for uploaded data independent of feature type . And
> also in Layer/Map Viewer ---> EDIT --> *CREATE option* is *disabled.*
> Please kindly help us in GeoNode which part of code/file verifies
> feature/Geometry type(Polygon/lIne/point) of Shapefile and assigns
> corresponding default SLD
> Kindly help us to resolve the issues
> Thanks&Regards,
> Naresh.N
> On Tue, Apr 9, 2019 at 2:58 AM juliermeopensourcedeveloper [via OSGeo.org]
> <ml+s1560n5401239h2 at n6.nabble.com> wrote:
>> Hi Naresh,
>> Could you provide the shapefile you are having problem?
>> Kind regards
>> Julierme
>> On Mon, 8 Apr 2019 at 08:28 Naresh N <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5401239&i=0>> wrote:
>>> Dear All,
>>> I have deployed the GeoNode 2.4 version by following the instructions
>>> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/setup_on_centos/index.html
>>> *ISSUE : *When I am uploading shapefile(polygon), it is taking the
>>> default point SLD. Hence when I am viewing the Uploaded Shapfeil(polygon)
>>> as WMS in Map/Layer View , it is displaying as point.
>>> *Kindly help me to resolve this issue. *
>>> GeoNode Deployed system configuration are
>>> *OS:*RHEL 7.2, 64 bit , GeoNode2.4 version
>>> Please let me know any other information required further to understand
>>> the issue.
>>> Thanks&Regards,
>>> Naresh.N
>>> geonode-users mailing list
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=1>
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> geonode-devel mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=2>
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-Uploading-Shapefile-Polygon-features-Displaying-as-Point-in-GeoNode-Map-layer-View-tp5401239.html
>> To unsubscribe from GeoNode, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185390&code=bmFyZXNoOTE5QGdtYWlsLmNvbXw1MTg1MzkwfC0xMDc3NTYzNDE5>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190409/6f3e3328/attachment-0001.html>
More information about the geonode-users
