[GeoNode-users] GeoNode questions (Magnus Nilsson)
Magnus Nilsson
johnrobot at gmail.com
Mon Apr 29 08:09:11 PDT 2019
Hi Toni
Thank you for the answer. It sounds like I should test again when mapstore
is the default client.
I have updated the Swedish translation to 100% on Transifex, hopefully
those updates will be reflected in the next release.
I will do some additional tests in the coming months and report any issues.
It would be great if we could use GeoNode + QGIS Server as a tool for our
QGIS users to easily create web maps from existing QGIS projects.
Magnus
Den mån 29 apr. 2019 16:23Toni Schönbuchner <toni.schoenbuchner at csgis.de>
skrev:
> Dear Magnus,
> - The web maps don´t seem to work well on mobile clients. Very small
> buttons and trouble zooming, for example. Is that being worked on? I
> tried
> with Firefox on my S9.
> There is an excellent alternative to GeoExplorer, which will hopefully be
> integrated
> as standard viewer soon:
> https://github.com/geosolutions-it/geonode-mapstore-client
> https://mapstore.geo-solutions.it/mapstore/
> - Is it correct that GeoNode does not support uploading GeoPackage
> files? We use this format quite a lot for our geodata and going back to
> SHP
> seems like a step in the wrong direction.
> Haven´t tested but it should work when using:
> https://github.com/GeoNode/django-osgeo-importer
> as Uploader.
> - When uploading a data set, I get an option for creating metadata. Can
> this step be made mandatory (including defining the mandatory fields)? I
> would like to avoid setting up an environment where users upload data
> sets,
> but skip the metadata step.
> As far as I know not out of the box. But it shouldn´t be too hard to
> customize
> geonode_project to work like this.
> https://github.com/GeoNode/geonode-project
> - When choosing to create a map from a layer, the view is not centered
> on the data set. Wouldn´t this be more useful?
> It does with Mapstore2 as Viewer ...
> - When I click ”Zoom To Max Extent”, the map zooms out to the whole
> globe (even without a background map selected). Wouldn´t it be more
> useful
> to zoom out to the extent of the data added by the user?
> Should work like this with GeoExplorer (this is the Viewer you might have
> tested)
> as well. Anyways, see the preceding answer :)
> - The ”Get Feature Info” tool doesn´t close the previous pop up
> window(s) when clicking again, so I can quickly get 5-10 windows blocking
> the map. Is this a known issue?
> Not reported by anyone yet.
> - Using the same tool, I noticed that Swedish characters (å/ä/ö) in
> attribute values do not work, using UTF-8 encoding.
> Well, this should definitely work. Unfortunately, this can have several
> reasons starting with
> your data import to geoserver. For things like that you´re always welcome
> to file an issue at Github.
> - I noticed that the translation to Swedish is incomplete and sometimes
> misleading. Is the latest translation pulled from Transifex for each
> official release?
> It is not, unfortunately, Transifex is outdated and people who contribute
> to translations are very welcome.
> With best regards,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 739
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190429/a81ef350/attachment.html>
More information about the geonode-users
