[GeoNode-users] (no subject)
Naresh N
naresh919 at gmail.com
Wed Dec 11 01:40:55 PST 2019
Dear All,
I could able to solve the issue. Now https enabled for GeoNode. The issue
is with httplib2 library. I have updated the httlib2(0.14.0) and given
GEOSERVER_LOCATION: *http://yourdomainname/geoserver
<http://ourdomainname:8080/geoserver>*
GEOSERVER_PUBLIC_LOCATION: *https:// yourdomainname/geoserver.*
Thanks a lot for all the help and support.
*Thanks&Regards,*
*Naresh*
On Mon, Dec 9, 2019 at 12:40 PM Naresh N <naresh919 at gmail.com> wrote:
> Dear Amedo/Simone,
> Please see once my post and reply. Not able to understand? Where the
> issue.
> Is following require for GeoNode to work as https?
> sudo -s "cat server.crt >> /usr/lib/python2.7/dist-packages/httplib2/cacerts.txt"sudo keytool -import -alias geonodessl -keystore /etc/ssl/certs/java/cacerts -file server.crt
> Please suggest
> Thanks&Regards,
> Naresh
> On Thu, Dec 5, 2019 at 4:07 PM Naresh N <naresh919 at gmail.com> wrote:
>> Dear All,
>> As I posted earlier, we need to enable GeoNode with https but facing the
>> issues. The following are added for https
>> 1. Apache Configured with https and required changes are added in
>> geonode.conf as per mentioned in
>> http://docs.geonode.org/en/2.8.1/tutorials/advanced/geonode_production/ssl.html
>> 2. Tomcat /GeoServer Configuration -
>> (i)Modified the Server.xml and done required changes
>> <Connector port="8080" protocol="HTTP/1.1"
>> connectionTimeout="20000"
>> URIEncoding="UTF-8"
>> scheme="https"
>> proxyName="<ourDomainName .. for example as* exmaple.com <http://exmaple.com/> *>"
>> proxyPort="443" />
>> (ii) Modified /var/lib/tomcat/webapps/geoserver/WEB-INF/web.xml
>> * Geonode_BASE_URL* to https://ourdomainname
>> (iii) Modified /var/lib/tomcat/webapps/geoserver/data/web.xml))
>> * Proxybaseurl *: * https://*ourdomainname/geoserver
>> 3. GeoNode Configuration - Changed Site Url to https
>> (i)
>> /var/lib/tomcat/webapps/geoserver/data/security/auth/geonodAuthProvider/config.xml
>> baseurl to https://ourdoamingname
>> (ii) In local_settings.py and setttings.py
>> a. sitename and siteurl to https://ourdomainname
>> b.GEOSERVER_LOCATION: *http://ourdomainname:8080/geoserver
>> GEOSERVER_PUBLIC_LOCATION: *https:// ourdomainname/geoserver *
>> After doing the above the changes , *our GeoNode portal is able to
>> access with https*, however the following functionalities are not working
>> 1. When we are uploading the data, the following error is appearing
>> Tried to make a GET request to
>> http://ourdomainname:8080/geoserver/rest/workspaces/default.xml
>> <http://localhost:8080/geoserver/rest/workspaces/default.xml> but got a
>> 404 status code:'
>> 2. Edit style is not working
>> https://domainname/gs/rest/layers/geonode:_11_19_2019_6450480_1.json
>> -- * notfound (error code:404)*
>> https://ourdomainname/gs/rest/styles/_11_19_2019_6450480_1.xml ---
>> error code 500 ( some internal server error)
>> In above both are *REST services which are not working* however, When I
>> tried to access *http://ourdomainname:8080/geoserver
>> <http://ourdomainname:8080/geoserver> it is redirecting to
>> https://ourdomainname/geoserver <https://ourdomainname/geoserver>* ( it
>> is loading properly)
>> Please kindly help me, is somewhere I need to do the REST services
>> settings.
>> Thanks&Regards,
>> Naresh.n
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191211/06cefdbc/attachment.html>
More information about the geonode-users
